I just got around to checking my tires pressures today after going to the track a few weeks ago. I found that the valve stem cap on the front right wheel had melted! The brakes must have been really smoking to generate that much heat.
Ariel Atom 205HP due April 2007
Mine have done the same thing. I use aluminum ones now. Can't remember where I picked them up.
Brad: don't!
The aluminum ones will break when rubbing wheel to wheel, while the rubber one is much more likely to give because of the flexibility. My guys at Hoosier insist on rubber valve stems...
Interesting, hadn't heard that before... maybe because I try not to rub wheel to wheel.
I'll have to stock up on the rubber ones I guess as they don't last long.
My friend had a metal valve stem in his Formula Ford break during wheel to wheel contact, causing his tire to instantly deflate.... He now uses rubber valve stems. They may not last forever like the metal ones, but spending an extra dollar when you are replacing wheels isn't a big investment.
Jonathan
2002 QS/ModRed
LG longtubes and x-pipe
It happened to Bob Kahn during the first race at Pocono. I try to learn from other people's experiences!
Thanks for the tip. I meant in my post above that I used aluminum caps, not stems, but when you mentioned a stem snapping off, I went and looked at my CCWs and they do have aluminum stems. Guess I need to change them out.
I don't even fool with caps any more. I know that's one of those things that Farmer is anal about, but I just leave mine off all the time. Hey, if nothing else, it reduces rotational mass! ha ha
There are other rubber parts that are even closer to your rotors than valve stems that you may want to look at now that you see some heat damage.....rubber boots around suspension parts and caliper pistons. I speak from experience.
