Vette brakes and products do a lot of testing with the C5, they work with the grandam race cars
not sure if you need coil overs, but i tried a stiffer front spring to help in braking and poly type bushings all around, this helped at the track, i also put on a little heavyer rate rollbar and found it push more and took it off, tried the bilstien shocks and did not like them and put the stock one back
