Old 05-07-2004, 10:49 AM   #1 (permalink)
Terrible Traps, What's wrong?
I just got back from the track and very disappointed. 02 Z, the only mod I had was the zip tie. I didn’t expect to have great ET’s with the stock tires, but my trap speed is horrible. Here is my first run;
Bradenton, FL Temps were about 80
60’ 1.966
¼ 12.954
MPH 108.51
I had a few more runs where the 60’ were 2.0’s (depending if I left traction control on/off), but traps remained in the 109’s regardless. I put the lid back on the air box just to make sure that wasn’t effecting anything, but the traps remained in the 109’s. I was expecting to see at least a 113-115. The car feels strong, but do you think there could be some problem. It has 21k miles on it.
RobBP500 is offline   Reply With Quote
Old 05-07-2004, 11:56 AM   #2 (permalink)
MikesZ06's Avatar
Rob, if you were just wringing it out a little at the track and not shifting hard, that could certainly attest to some loss in trap speed. The warm temps would also play a role but I'm guessing that if you shift a little harder next time, your times may go down 2 to 4 tenths and your traps will be in the mid teens.
9.87 at 141mph
& 2007 Black C6 Z06
Old 05-07-2004, 12:51 PM   #3 (permalink)
I was shifting @ 6200. If I went to hard on the 1-2 shift the rear would break loose.
Old 05-07-2004, 01:20 PM   #4 (permalink)
You need tuning.
Our car off the showroom only ran 110mph. After tuning, 114mph.
Zero out the IAT retard table, fans on earlier.
Blue Meanie 02' Z06 440rwhp AFR 205-224/228, Kook's 1 7/8", SDPC 3.73 Getrag, 11.40@119 w/1.59
SCCA Solo2 ESP #58, Team No $'s. AutoCross Pic
Pat McSwain, co-driver Kathy McSwain
Old 05-07-2004, 01:21 PM   #5 (permalink)
Oh, and shift at the limiter. The higher you shift, the quicker it goes.
Old 05-07-2004, 02:15 PM   #6 (permalink)
2002 TR Z06, Borla 4 tip Stingers, K&N, partition, Chromies, CAGS defeat 2002 Honda VTX 1800
2004 Nissan Maxima SE
2003 PT Cruiser "Dream Cruiser' Turbo
floridared is offline   Reply With Quote
Old 05-07-2004, 02:19 PM   #7 (permalink)
Rob - I ran at Gainesville last winter and couldn't get traction because of the weather, about 48 degrees, but my trap speed was over 110 and that was backing off to keep the back tires from hopping around.
I also have an '02. Unless there's a problem, I suspect you should be at 113 to 115. Going again tonight (temp 92 degrees now) and hoping for some traction.
Ron
Old 05-07-2004, 04:37 PM   #8 (permalink)
Weather has a lot to do with times and speeds. It's already starting to get humid here in Florida and it will only get worse as we move into summer. The high heat and humidity in Florida will easily add a second to your time and also reduce your trap speeds.
Old 05-07-2004, 07:49 PM   #9 (permalink)
Keep practicing Daniel son! It will get better trust me my first time out i was running 13.05 at 112with a little practice and some mods im down to a 11.77 at 123.
z06blueman is offline   Reply With Quote
Old 05-07-2004, 08:02 PM   #10 (permalink)
Shoot, my first time I was do'in 13's.I got the Z down to 12.5 at 115.90 but still could not get traction.I'm still new at whole 300 plus footpounds torque at 2700rpm.Goodluck
Brandon619 is offline   Reply With Quote
Old 05-07-2004, 08:15 PM   #11 (permalink)
jdk
Send a message via AIM to jdk
That's a bit better than my best at bradenton, even shifting _hard_. So don't feel too bad.
My best was 13.1 at 110mph
jdk is offline   Reply With Quote
Old 05-07-2004, 08:21 PM   #12 (permalink)
I agree the weather now in Florida will kill your times and trap speed. But also you need to try and shift around 6500 and fast as you can. The rear should not break loose in your shifts unless you are shifting too slow(not smooth enough) and if your tire pressure is too high. You may experience some wheel hop during the shifts but you shouldn't break loose enough to let up in the Florida heat. I would make sure you heat the tires and try a longer burn, lower the tire pressure, and shift faster at the limiter. I know, its easier said then done but you'll get there with alot of seat time. Use these hot days to practice and in the winter go for you personal best. Goodluck.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 05-07-2004, 08:58 PM   #13 (permalink)
Humidity will kill your top end and make the engine breath poorly. We raced for years on and off at Orlando and avoided the heat and humidity if I wanted to run fast.
Up here in the mountains when it gets humid my mph drops
3-4 mph. So when it's hot and humid I don't race. Why waste my time and whip ass on the car.
Get a 160 degree t-stat for Florida.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 05-08-2004, 06:29 AM   #14 (permalink)
Need more information. For me it comes down to
TIRES TIRES TIRES
fully inflated, low 13's. 20lbs, mid 12's. sticky tires, low 12's.
also seat time helps a lot. now i prefer a 20 min. rush at the
auto-x rather than 12 sec. in a straight line.
I Wish the passing lane had a Passing Lane!
Slo Z-06 is offline   Reply With Quote
Old 05-08-2004, 11:38 AM   #15 (permalink)
I have raced at Bradenton which is an amazing track and I have been there in winter and summer and there was a 3-4 mph difference.
2006 Victory Red Z06
490 rwhp 465 rwtq
GaryZ06 is offline   Reply With Quote
Terrible C6Z brakes/pads, I hate them! ghoffman Racing 17 01-08-2006 08:43 AM
Latest issue of R/T. C6 places LAST in all speed traps jnjboc C6 Z06 - Grandstand 23 08-03-2005 11:27 PM
1/4 traps speeds, stock vs. aftermarket cam Dave C. '04 Z06 Racing 5 01-27-2005 01:29 PM
Terrible bearing whine or equivilent 22655TD C5 Z06 - Pit Road 2 10-02-2004 02:57 PM
Vette-less for a week. The withdrawals are terrible. CorvetteSS C5 Z06 - Grandstand 7 11-10-2001 12:06 PM
