Tonight will be my first run at the track with my BFG Drag Radials. Can somebody who has run these tires extensively tell me what tire pressure would work best for launch?
I have the 315/35-17 tires on 17X11 CCWs.
Thanks!
What happened to my pic??? 2002 Blk/Blk LS2 402, STS Twin Turbo, Spec V, HPTuners 2Bar Speed Density Tune by RalphP
yea, test between 18-12psi, some people work better with a good burnout but I only seem to do good with a short clean sweep thats a good thing I guess, motor cooler and less tire wear
- pull around the water box
- back into it, just get the tires a little wet. You don't want to fling water all over your wheelwells
- pull out of the box
- car in first, clutch in, bring the revs up
- drop the clutch and move your left foot to the brake pedal
- apply just enough brake pressure to keep your car from moving (or moving quickly if it's your first time)
- sit and smoke
- you will know the tires are getting hot as the traction drags your revs down. When this happens, roll out. The tires are ready.
It helps if you try this on your stock tires in the rain first, IMO. Doing it on sticky tires at the track is asking for the possibility of an embarrassing stall or worse yet, smoking your clutch on your burnout.
Thanks Wayne: I'm gonna go without burnouts tonight and take your advice on practicing in the rain on my street tires first to get it down. Too much adrenaline flowing at the track to try to get this right the first time. Or, I will try it at the next Test&Tune. Appreciate the advice!
without a burnout you'll do better then over heating them due to the fact that when you overheat them as you launch it doesnt get any cooler ofcourse, if you have the right psi and the tires are dry, launch from 3500 rpm and by the time you are half way into 1st they will be hot enough for traction actually as long as DRs are on a roll and hooked they wont loose traction at all
I tell you what, go around the water box and launch it like you would be launch hard just for fun, they will get hot enough and you'll be ready to rip it
Thanks! So are you saying to go ahead and spin them a little when it is time to move from the position next to the water box up to the staging lights?
yea thats what I was saying, it would pretty much be a burnout, but if it will make you nervous dont worry about it, drive around the water box, I just figured you would be moving the car to get to the staging lanes might as well floor it and that would almost complete a burnout, but air pressure is more important in my opinion, in this weather at least
wait a minute Ralph, I just noticed your sig, 440rwhp and 3.90 gears , yea!!!! you eventually going to need a burnout to get some better times, launch at 3500rpm the first time and dont get throddle happy, take Rmps all the way up and dont power shift the first time out only if you already got it down packed on the street, you'll see a low 12 at around 122mph
I sure appreciate your enthusiasm, but Bandimere speedway is at 6000 feet elevation. The numbers in my sig are corrected for sea level so I am lucky to be putting down about 375 in reality. My best so far with stock gears and tires and a 2.1s 60 ft time was a 13.40 @ 109. I am hoping to break into the 12s tonight though.
I managed three practice runs even though two are allowed.
First run I forgot to drop the tire pressure so forget that one - spun like butter.
Second run tire pressure down, 3K launch, bogged a little, bounced off rev limiter due to getting used to 3.90s - forget that one too!
Third run, began to get it down, ran a 13.4 @107.9 with a 2.06 60ft
First comp run, dialed a 13.5 and planned to sandbag a bit if needed. Got passed by a 11 sec '60s Mopar , launched around 4K, ran 13.315 @ 108 with a 2.03 60ft, but he red-lighted.
Last comp run, dialed 13.3 launched 4500, ran 13.24 at 108.1 with a 1.97 60 ft and had a grin on my face because that run felt good - like I am starting to get it. Never mind that the fricken Kawasaki dialed 11.71 and ran 11.710 !!
Haven't got the two-foot burn-ins down yet. ALSO, haven't dropped the clutch, more of a smooth release.
Anyway, had a blast and I feel like I will get consistent once I figure the best launch. I made a ton of progress skill-wise in one night. I will do a couple of test and tunes before the next meet to work out the burn-ins, work on launch and try power shifting. I should break into the 12s. Then I will just have fun and see how consistent I can be.
Thanks so much for the advice and encouragement. This is really fun!!!
keep us updated....... Im curious if you get into the 12s my best run is a 13.1 in Alb,NM about 5500 ft elevation... stock tires. Im hoping to get into the 12s with my drs.... nice to hear that you already droped your time already.....
Altitude is a killer. But if you ran 13.1 on stock tires then you will be in the 12s with DRs. They make a real difference. I presume your car is not stock?? Stock Zs run about 14 at Bandimere.
