Originally Posted by landho
How can it be both (too high or too low)?
So this oversteer/understeer thing is related to decreasing/increasing sidewall flex? I know other issues can cause over/under steer...but I am interested in understanding the effect of tire pressure only...
Thanks.
It can be both because it there is a "threshhold" correct pressure.
Say your pressure is very low on the front tires. All else equal this causes understeer due to a high slip angle (fancy way of saying tires are rolling over/towards sidewall). Adding pressure will help alleviate this understeer. Now if you add too much, tire gets high in center, reducing contact patch, again causing understeer.
I start with about 32 front 31 rear with Toyos on road courses. When I run my Hoosiers I start at 31/30.
Right now my Z, with has good negative camber alignment, T1sway bars, and warm Hoosiers turns in like a bitch, it's just awesome. Mild oversteer at limit, controllable with throttle say, in a carousel.
