Originally posted by stevethe6th
I'm getting close to putting the Z06 on the track for some DE events. All the safety stuff is done (harness bar, harnesses), but I need some opinions on the following items:
1. Frozen Rotors - I have heard that stock GM rotors don't live long at the track. My P-car buddies swore by these rotors. At just over $100/ea for the vette, it seems like a pretty good idea. Opinions?
You can get raybestos rotors for $100 shipped for all 4 now. They are the same as the NAPA rotors which I ran for 7 track days last year.
2. Best pads for track-only use (I'll swap to stockers when I get home)?
I hear the carbotech XPs are very good. Bit less then the PRC 01s. One of the T1 guys here seems to think they are very close. Your stock pads are not bad, they will taper a bit though.
3. Anyone tried Redline MTL Shockproof gear oil? It worked great in my 944TS, but I'm not sure if it's suitable for the vette tranny.
You only want to run ATF in the Z06 6sp tranny. Amsoil, redline or mobil 1 synthetic will work fine.
4. I bought a new set of rims and some Toyos for the street. I plan to use the 75%-gone F1's for my first track event. What kind of (hot) pressures do they like?
I like to start out at 30psi cold with the stock F1 SCs. Watch the wear arrows on the sides. If the tire does not roll over to the arrow let a lb or two out. If they are rolling past the tip of the arrows add a lb. Mine are usually about 35-37 when hot.
This is what will happen if you run too much air, I started this day with 35 cold. You can see where the tire was not rolling over to the arrow that day. I showed this to the panoz instructor who drives a Z06. He told me about letting the tire roll over to the arrow.
5. Has anyone tried extending the air dam below the radiator for track use? It would seem like an additional inch or so would provide improved cooling. I doubt it would get torn-up unless things get agricultural.
Never have seen that done. I use a fan controller and my water does not go over 210* with the stock stat.
If you get the "high trans temp"warning on the DIC hit the reset button to get your actual tranny temp. The warning comes on at 270*f. This is the only time that you will see the tranny temp displayed. You should then do a cool down lap and let her sit till the next session. You may need to carry more speed thru the turns and downshift less.
Don't forget to run 1 quart over the full mark during track events as GM says to.
Have Fun!!!
