Old 02-25-2004, 01:31 PM   #1 (permalink)
Track Tire Sizes
Can 315/35 x 18 tires be used on the stock rear Z06 wheels, or are they too wide for the wheels? Road course, not drag racing.
RobSan is offline   Reply With Quote
Old 02-25-2004, 01:39 PM   #2 (permalink)
Here is an interesting read on the subject...
tire size discussion
ack.Z06 is offline   Reply With Quote
Old 02-25-2004, 02:03 PM   #3 (permalink)
Thanks Josh, I had already seen that discussion, but it sort of hits on both sides of my question. I really want to know if anyone has good experience with the 315's on the stock 10.5" wheels. I am pretty comfortable with the 305's on stock, or the 315's on 11", but remain curious about the above. Thanks, good info from all though.
Old 02-25-2004, 07:08 PM   #4 (permalink)
Rob,
Never done it so I'm just guessing here, but...
I run 315/35-17 on 17x10, so by implication, I'd think a 315 would fit on a 10.5 inch rim.
31/5/35-18 seems like it would be too tall. What tire is that size, I couldn't find any?
The closest I could find was a 315/30-18 Michelin Pilot Sport Cup. The Tirerack spec sheet says it will fit on a 10.5 inch wheel and height is 25.5", which is just short of stock, but almost identical to the height and width of the 315/35-17s I'm running.
Hey not to hijack your thread, but I'm doing a bunch of off season maintenance to my car this Saturday starting about 10am. PM me if you're interested in coming over and checking it out and I'll let you know where I live. I'm having several other vette owners come by.
- front lower a-arms
- all four calipers
- all four rotors
- pads all around
- plugs
- engine, tranny, diff oil
- radiator fluid
- brake lines
Old 02-25-2004, 08:07 PM   #5 (permalink)
Brad - thanks, I had the same thoughts. The Kumho V710 is a 315/35R18 with 26.4" OA diameter vs. the stock MX of 26.7", so not much difference and actually smaller. The front is 25.4" vs. 25.8" on the MX which I run on the street. Anyway, thanks and PM to follow regarding Saturday.
Old 02-25-2004, 09:21 PM   #6 (permalink)
Rob,
FYI, the stock 295/35-18s are only 26.1 in diameter.
The Kumho Ecsta MX in 295/35-18 is also 26.1 per tireracks spec sheet.
26.4 is pretty close. For some reason I didn't think to check the V710s. The spec sheet for the 315/35-18 says it will fit a 10.5 inch wheel. Your going to get some buldging though, so effective width will be slightly less than 315.
Old 02-26-2004, 06:30 AM   #7 (permalink)
Actually, I have the V710's mounted on 18x10.5 CCW's. No buldge. The tire fits as perfect as I've ever seen any race tire fit. The corners of the V710 are much more rounded than the previous Victoracers and the Hoosier A3SO3's. That may also be helping with the lack of buldge.
-Don
DKTZ06 is offline   Reply With Quote
Old 02-26-2004, 06:40 AM   #8 (permalink)
Thanks Don, just wanted to hear from someone who had actually run them on that rear rim size.
Rob
Old 02-26-2004, 01:20 PM   #9 (permalink)
Rob, you are going to LOVE the rear grip from the V710's. If you're used to the 305/30's Hoosier break-loose tendencies, you'll be amazed at how much more grip you have with the V710's. I was able to be *really* rough with the car and the rear stayed planted.
-Don
Old 02-26-2004, 01:26 PM   #10 (permalink)
If it's any help, there are at least 3 dozen of us running the 315 V710s on stock rear rims in SCCA Solo2 already, and they seem to work fine!
SD7SS is offline   Reply With Quote
Old 02-26-2004, 03:25 PM   #11 (permalink)
Thanks, convinced, ordering.
Rob
Tire Sizes Trainer C5 Z06 - Pit Road 8 06-11-2005 12:20 PM
SS Tire Sizes Henry Bjoin C5 Z06 - Pit Road 0 01-30-2005 08:34 PM
tire sizes DMZ06 C5 Z06 - Pit Road 6 11-07-2004 05:39 PM
Tire Sizes ed a C5 Z06 - Pit Road 0 10-20-2004 01:20 PM
tire sizes 17/19 tahoe Z C5 Z06 - Pit Road 1 10-27-2003 01:41 PM
