Old 06-25-2004, 09:48 AM   #1 (permalink)
Send a message via AIM to davidsz06
Use Traction Control or Not
For drag racing on street tires....
I want to leave traction control OFF and babying the car off of the line, but someone told me to leave it on and let the engine control tire spin.
I don't want the car deciding for me. I have a lot of experience drag racing on slicks, but not much with street tires.
Any thoughts?
David
davidsz06 is offline   Reply With Quote
Old 06-25-2004, 09:53 AM   #2 (permalink)
Thought: Turn it off.
2008 MS Z06
1957 Corvette
2004 Red Yamaha R1
2003 QS Z06 with ModRed interior- Gone to a new home now, but never forgotten
Jagrmaister is offline   Reply With Quote
Old 06-25-2004, 10:14 AM   #3 (permalink)
Registered User
Turn it off. If you get any tire slip, it's going to bog the engine. This would make the car worthless in a drag race.
Comp Mode = yes
Traction Control = no
X
Old 06-25-2004, 10:26 AM   #4 (permalink)
Most everyone turns it off.
Sig by the Hillbilly!
Old 06-25-2004, 10:28 AM   #5 (permalink)
competitive driving
Dr Octane is offline   Reply With Quote
Old 06-25-2004, 10:31 AM   #6 (permalink)
Registered User
I don't drag race, but I would use comp mode if I did. The active handling should never come into play unless you were about to lose it and end up against the wall otherwise. Those walls are so close to the track at the drag strip.
X
Old 06-25-2004, 11:07 AM   #7 (permalink)
Off!
BIG-DAL is offline   Reply With Quote
Old 06-25-2004, 11:26 AM   #8 (permalink)
Registered User
We should ask the question again, but find out how many people prefer comp mode to turning everything off for drag racing.
X
Old 06-25-2004, 11:29 AM   #9 (permalink)
FiveOJoe's Avatar
Comp mode
sig by nutbush
Old 06-25-2004, 11:44 AM   #10 (permalink)
Comp-mode. In fact I'm thinking of getting the laptrax system that causes the car to sarted up with the comp-mode as default.
Halltech Trap, LS2 90 mm TB, LSX F.A.S.T. intake, heads/cam, Dynatech SuperMaxx LT headers, GHL bullets catback, Fidanza flywheel, Spec 2/3 hybrid clutch, DTE 3.73 differential, DTE differential strut, cags defeat, traction control defeated, shorty antenna,
Kickin is offline   Reply With Quote
Old 06-25-2004, 11:49 AM   #11 (permalink)
X
I use Comp. mode on the street, but everything OFF at the track because the Comp. mode does not light up on the dash. I monitor the engine temp. on the DIC. I had a few runs that I forgot to put it in to Comp. so I just turn it all off now.
-D.
Old 06-25-2004, 11:52 AM   #12 (permalink)
Comp mode. ALL ON will increase your times about .2-.5 seconds due to the "lag" that happens after it removes throttle. It doesn't reapply the throttle quick enough.
Blue Meanie 02' Z06 440rwhp AFR 205-224/228, Kook's 1 7/8", SDPC 3.73 Getrag, 11.40@119 w/1.59
SCCA Solo2 ESP #58, Team No $'s. AutoCross Pic
Pat McSwain, co-driver Kathy McSwain
Old 06-25-2004, 11:53 AM   #13 (permalink)
-D.
Set it COMP, then hit reset on the DIC.
Old 06-25-2004, 12:33 PM   #14 (permalink)
Registered User
Hit the reset button. That's what I do at the track, so I can go through all the readouts. I usually cycle through the gauges when I'm on the long straights.
X
Old 06-25-2004, 12:46 PM   #15 (permalink)
Thanks!
would have been a good poll question. I'll leave it off :-)
Can it be set to be off as default? I notice that it is on unless I turn it off. If I forget during the elimination bracket races, i'm screwed!
Also, are there vendors at the track during the challenge series? If so, i'll bring some extra cash.
Also, I'm going to shoe polish a Z on my upper right back windowso i can be identified as a Z06 VETTE member.
David
03 Mil. Yellow Z06 - STOCK! :-)
Traction control beerkat C5 Z06 - Pit Road 11 12-12-2006 11:19 AM
Traction Control LethalZ C5 Z06 - Pit Road 13 06-07-2006 06:33 PM
FS: Brand new RaceLogic traction control system with launch control jimlab Member Sales - Parts & Cars 14 12-31-2005 03:51 PM
Traction Control... SomeGuy604 C5 Z06 - Pit Road 9 08-21-2005 11:34 PM
Traction Control ? ZO6/Les C5 Z06 - Pit Road 19 11-16-2001 06:31 AM
