Water Temp- How High is High?
I have a question to those who are tracking their Z06’s. Specifically you must be using a stock radiator and:
1. See high oil temps – above 250 F – No oil cooler
2. Or are using an air-to-air oil cooler
3. Or have first hand knowledge, like a friend, and you where out at the track with them.
What is the highest on track water temps have you seen?
Background: I had been tracking my Z06 and after seeing 290 F in 75 ambient temperatures I installed a DRM oil-to-water cooler. Oil temps where in the 240 F range and water temps around 230 F in 95 – 100 ambient temperatures. I track the car in the Texas area. Very long story, but I removed my DRM oil-to-water cooler and everything is stock. I am planning to go back to the track and I will need an oil cooler.
An air-to-air cooler cost wise is very nice, but I am worried about my water temps. I ran into some folks who are running T1 in SCCA last year. They could use an air-to-air oil cooler, but had to use the stock radiator. They were running some high water temps, 260 comes mind. Thus my concern.
That's it
Dave
Drive only as fast as you can see.
