I have my Z06 for about 5 months now, still trying to perfect the perfect lauching technique. When I rev up and drop the cluth @ 4000 rpm my rear wheel hops violently.
I have Pirelli's PZero Rosso Size:295/30-19 at the rear and 265/35-18 in the front.
what causes the wheel hopping? Any advice and suggestion will be greatly appreciated.
The basic cause is the tires getting and then losing traction and repeating rapidly. Some things that can make it more pronounced are the shocks rebound valving, the design of the rear suspension, tires, tire pressure, suspension bushings and launch RPM.
The vettes independent rear suspension and shock rebound damping are big factors.
Some things you can try are more fuel (full tank) which of course adds more weight and therefore aids traction, lowering the tire pressure, and trying a lower launch RPM.
Interesting..... I don't think I've seen wheel hopping mentioned as an issue with the Z very often - also haven't seen the Pirelli's mentioned much. Maybe we need a survey...
For many years I drove a Saab turbo (hey, GM liked them enough to buy them.. ) Over the course of many miles and many tire changes I noticed a starteling difference in hop with tire selection. Coincidentally, the hop was worse with a Pirellli. For me overall, the biggest factor that is the easiest to control is the tire. Unfortunately only trial and error will tell the story.
Good luck. I can vouch for the factory F1's, they don't seem to hop under any conditions.
Its my belief that the hop is caused by the rear suspension bushings flexing too much. It has been my experience, that any sort of compliance out back will cause wheel hop.
If you have the compliance pulled out, and still have hop, start looking at the shock valving.
thanks
Say there Red,
I have the same size combo but MPS's and if the pressure is too high she'll hop every time I pull a gear. I've found 22-24 psi to pretty good. And I don't lauch that high with street tires. I don't know about all the other variables, maybe I just lucky to resolve it with tire pressure, also like a someone said above....I'm not a Pirelli fan either. Good luck, there's a lot of trial and error.
