Ok, CCW makes the 10x16 wheel.. and to make them work you don't need to grind the control arm, All you need to do is knock the point off the upper ball joint.. you cam take a hammer or a small grinder and do this real easy.
17" wheels I think you can use ZR1 wheels with a offset, not sure as I don't use them but some have.
You might even fins a used set online. If you do got with ET Streets, make sure you have Skinny's up front (bias) ply tire.
If you go with the DR Radial version of the ET's then you can run you stock tires up front.
Hope this helps.
Ernie
2000 FRC Nassau Blue
10 Second Club
