Old 01-17-2005, 12:36 AM   #1 (permalink)
The best way to burn out without a LINE LOCK?
guys im new to drag racing and faced alot of problems in launching my car on the strip due to major wheel spin in 1st and 2nd gear and its all because I dont burn my tires alot coz of the ABS brakes locking the rear tires.
how do you usually burn your tires before drag racing? whats the best way in your opinion?
thanks!
ebrahim
MTI stage 2 heads, X1 cam, LG headers, 90mm LSX intake, B&B bullets exhaust system, vararam, air bridge, hurst shifter, Exedy twin disk clutch, tuned by MTI
best E.T 11.78@119 (cam only)
405bhp is offline   Reply With Quote
Old 01-17-2005, 05:57 AM   #2 (permalink)
line lock allows more consistency in the process, back into water, pull forward out of water, set line lock, put into gear, drop clutch and hold rpm above 5000...wait for tire smoke to pass driver window (5 seconds?) and then release and roll-out of burn...as short a distance as possible...then stage and hammer....some like 2nd gear burn.
Sorry - I just saw that question was "without linelock"...my comments are for with linelock....
C5 CU is offline   Reply With Quote
Old 01-17-2005, 07:11 AM   #3 (permalink)
PerforminNorman's Avatar
Turn the traction control off. Leave the active handling on (JMHO). Run the RPMs up to about 5k or so (depends on where you feel comfortable) then pop the clutch and immediately move your left foot from the clutch pedal to the brake pedal and apply just enough pressure to keep the car from moving but allowing the tires to spin.
Btw, do not do this "IN" the burnout box but roll thru it and do it just on the dry side of the box.
Here is some footage of me doing this technique on concrete.
http://performin.homeip.net/videos/burnout.mov
Come to the Z06 Fest!
Performin' Norman
Old 01-17-2005, 09:04 AM   #4 (permalink)
MSiska's Avatar
Norm's description is very good. Exactly what I do except in 2nd gear. The tires will spin faster in 2nd and you will be less likely to bounce off the rev limiter.
Old 01-17-2005, 10:14 AM   #5 (permalink)
MikesZ06's Avatar
Everyone has their own opinion on this, but I'm not convinced that doing a true water box burn out on stock Goodyears does much good. Since they are not a true drag radial or sticky tire, anything more than getting the tires warm before the run is wasted tread IMHO.
9.87 at 141mph
& 2007 Black C6 Z06
Old 01-17-2005, 11:08 AM   #6 (permalink)
Send a message via AIM to benenati379 Send a message via MSN to benenati379 Send a message via Yahoo to benenati379
I agree with Mike. The only thing I'm sure that a "burnout" with stock tires does is rip up the rubber and track prep for the drag cars that really need it.
If you do have a DR or a slick and you'll be going to the track frequently, then the best thing to do is install a line lock. You'll be more consistant and have less wear on the drivetrain/brakes.
Vince
benenati379 is offline   Reply With Quote
Old 01-17-2005, 11:20 AM   #7 (permalink)
MikesZ06's Avatar
Originally Posted by benenati379
..... The only thing I'm sure that a "burnout" with stock tires does is rip up the rubber and track prep for the drag cars that really need it.
Old 01-17-2005, 03:54 PM   #8 (permalink)
ill be using my DR.. but is line lock necessary? do you all have line lock or u really dont need it? some say its a waste of money??
Old 01-17-2005, 03:57 PM   #9 (permalink)
thanks Norman.... nice video
Old 01-17-2005, 05:21 PM   #10 (permalink)
It isn't necessary, but if you'll be tracking the car often, it will definitely be a help. Burnouts will be easier and more consistent.
Old 01-17-2005, 05:33 PM   #11 (permalink)
Easier on the brake pads also.
Old 01-18-2005, 05:35 AM   #12 (permalink)
If you don't want to use the line lock then do as described by PerforminNorman above...i.e. rev release clutch and quickly move foot to brake...can be frustrating ... but if you have a line lock you set the brake then release clutch, you don't have to do all the foot movement...really does eliminate or reduce chance for error...
Old 01-18-2005, 06:54 AM   #13 (permalink)
Originally Posted by C5 CU
If you don't want to use the line lock then do as described by PerforminNorman above...i.e. rev release clutuch and quickly move foot to brake...can be frustrating but if you have a line lock you set the brake then release clutch, you don't have to do all the foot movement...really does eliminate or reduce chance for error...
Not to meantion embarrassment if you mess up and kill the engine.
Old 01-19-2005, 08:02 PM   #14 (permalink)
[quote=MSiska]Norm's description is very good. Exactly what I do except in 2nd gear. The tires will spin faster in 2nd QUOTE]
You don't need no stinkin' line lock!
Ron
Old 01-20-2005, 12:00 PM   #15 (permalink)
Send a message via AIM to LS6NickM
What linelock are you guys running? I went to the track last night with my nittos for the firts time and had a hard time heating them up real well. MY 60 foot times stunk.
2001 Quicksiler/Black Z06, Borla Headers, 2 Tip Stingers
MSD Wires, Ported TB, Carbon Fiber Air Bridge
K&N Intake, Fan/Cooling Kit
LS6NickM is offline   Reply With Quote
line lock scramblerman C5 Z06 - Pit Road 4 12-17-2006 11:49 AM
Line lock Big Red Machine C5 Z06 - Pit Road 6 08-16-2005 07:08 AM
line lock ? zo6dude C5 Z06 - Pit Road 1 03-25-2004 06:25 PM
who has a line lock? bumble bee Racing 12 11-02-2003 06:21 AM
Has anyone done a line lock? ZO6Cam C5 Z06 - Pit Road 7 08-02-2002 04:01 PM
