Old 09-09-2003, 08:58 PM   #1 (permalink)
What's a good sixty foot time?
I'm running stock everything except for a K&N filter? I've been doing 2.0s to 2.2s consistently for my 60's. My personal best is 1.9. I tried to search the forum for some data on this but couldn't find much. (I'm sure it's there somewhere.) And I see the odd bit of data in some signatures. So my question. What's a good 60' time? What are some of the easy tricks to improve? I'm not looking for mods. I'm looking for ideas on how to drive better...
Thriller is offline   Reply With Quote
Old 09-09-2003, 10:09 PM   #2 (permalink)
Good question. I wondered the same myself. My best on f1's is 1.969. I think anything in the 1.9X is pretty good. I'd like to know the best 60 foot on f1's for other members
BPP Long Tubes, Spec 2 Clutch, Drilled and Slotted, Hardened Output Shaft, BPP Edit, Corsa X-Pipe, No Cats, Indy Corsa's Pro's, BPP Ram Air, Vortex Power Duct, BPP Ported T.B., TB Coolant Bypass, Kirban Custom Shifter, Momo Cobra Knob, Tints, Lowered
Z-Ya Later is offline   Reply With Quote
Old 09-09-2003, 11:04 PM   #3 (permalink)
Track conditions and environment play a very large part on your 60' times. Here is my .02
Drop your rear psi to 20 - 24 PSI...Inflate your fronts to 46 PSI.
Drive AROUND the water box but back slowly near it and do a 1-3 second burnout to clean the rocks and dust/kitty litter off of your tires. Make sure absolutely NO water is on the tires -- they will be slightly sticky to the touch. There should be NO water in the wheel well either. This is the #1 cause for poor 60' times -- water.
Launch that Z at around 2K - 3.5K but no more. The F1's can't take a faster launch. You should hear a slight screech at launch but thats it. There should be zero wheel hop.
Practice. Get on the freeway at rush hour and wait for those red light/green light things at the on-ramp. Hell, thats free launch-day.
Take care.
Internet Consultant
Garry
1st. 1994 FRC (Black)
2nd. 2000 FRC (Black)
3rd 2000 Vert (Bowling Green)
4th. 2003 Z06 (Electron Blue)
5th 2005 FRC (Silver)
z06addikt is offline   Reply With Quote
Old 09-10-2003, 07:43 PM   #4 (permalink)
Thanks Z06addikt. Sounds like good advice. I'm going to the track this friday night and I'll try everything you've suggested. I'll let you know how I make out.
Question: when cleaning the tires for a few seconds, I'll just back up close to the water box, take her up to about 4K and drop the clutch, right? Or are you suggesting a brake stand?
Old 09-11-2003, 02:45 PM   #5 (permalink)
Send a message via AIM to 02 Z06 Racer Send a message via Yahoo to 02 Z06 Racer
My best 60' time is 1.83 on F-1's and it came from leaving the line at 1700rpm's. I leave my rear tire psi at 30. Decreasing the psi below that didn't work for me. The first 60' should also feel smooth for the best 60' times on F-1's.
2002 Z06 100% stock, F-1's
Best ET: 11.99@117.63
Best 60': 1.838
Sold
C6 Z06 in 2008
02 Z06 Racer is offline   Reply With Quote
Old 09-11-2003, 05:47 PM   #6 (permalink)
That's an amazing time, 02 Z06 Racer! More than a full second faster than my best time for the 1/4. I guess I've got some learnin' to do.
When you launch are you letting the clutch out real fast, or just fast enough to keep the tires from hopping? I assume the latter?
Old 09-12-2003, 09:27 AM   #7 (permalink)
I let the clutch out quickly but I don't pop the clutch as most do when they run DR's or slicks. I also have the advantage of racing at one of the best tracks in the country, Maryland Int. Raceway.
Old 09-12-2003, 01:09 PM   #8 (permalink)
I lucked into a 1.80 60' and 11.74 on my stock F1's. I dropped the clutch at 2000 rpm's with the tires at 25psi and it stuck. I wasn't able to replicate it on the next pass (I pulled a 2.3 60').
It amazes me how some people can slip the clutch at the track. I can do it on the street all day long, but put a timing tree there and I just can't do it.
2002 Black Z06
383 Lunati Stroker
Best ET 10.47@133.3 MPH 1.55 60'
Reboot is offline   Reply With Quote
Old 09-12-2003, 07:53 PM   #9 (permalink)
I hate to say it but putting a pair of bfg drag radials on will not only lower your 60 ft time but will give you a better feel of the car and track making you a better driver ,i went from 2.0s to 1.62 and can understand now what it takes on any tires .
JACK FRISSINA is offline   Reply With Quote
Old 09-13-2003, 07:27 PM   #10 (permalink)
Jack:
What rpm are you leaving at? Popping your clutch or riding it?
Thanks
george
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 09-14-2003, 06:40 AM   #11 (permalink)
Some excellent advise in this thread. Tire pressure will vary depending on track conditions, I find 22-24 PSI best, a full 2 second dry burn-out, launching at 1800-2200 (again depending on the track), lifting the clutch and pressing the go pedual as opposed to dump and stab.
Bottom line is practice and experiment, what works me may not work for you, different drivers, conditions etc. Practice is the best mod
I have managed a series of high 1.8X 60' times when the rubber was fresh, results in sig.
Les
[sold] 02 QS Z06 383 c.i.
Does anyone have a connection at Foot Action, Finish Line, or Foot Locker? architect The Garage 7 01-28-2006 07:50 PM
Not so good time with the Z...for once. Jagrmaister C5 Z06 - Pit Road 5 04-25-2004 12:03 AM
ZERO to SIXTY (finance) RatedZ The Garage 1 04-04-2003 07:54 PM
Your best 60 foot time's and Technique Z-Ya Later Racing 3 02-15-2003 11:25 AM
zero-----sixty robz Racing 21 12-01-2002 07:26 PM
