Old 03-31-2005, 11:09 AM   #1 (permalink)
Wheel bearing grease question
I will be re-packing the front wheel bearings prior to a DE. I was planning to use the Bell Ray stuff I have used in my trucks for years. I will be putting Carbotech pads on and got to thinking about elevated temperatures, drop points and the like. Is there a preferred grease or am I just thinking too much again - my wife calls me the king of overkill - but then she does not read this forum
Old 03-31-2005, 11:25 AM   #2 (permalink)
Wheel bearings are sealed and a no maintenance item!
Sig by the Hillbilly!
jub jub is online now   Reply With Quote
Old 03-31-2005, 11:44 AM   #3 (permalink)
That sure took all the fun out of his day! No grease.
Bob
Old 03-31-2005, 01:41 PM   #4 (permalink)
Well, that's what happens when you ask a question without ever lifting the vehicle.
So just leave them alone until the wheel fall off or the seize to the spindle - and then the wheel falls off .
But seriously folks, how do you check the health of the bearings to avoid three wheeling at 150 mph?
Old 03-31-2005, 01:52 PM   #5 (permalink)
DJWorm's Avatar
Change them every year as annual Winter maintainance for tracked cars.
Check them before each event.
AMSOIL Online Store
Old 03-31-2005, 01:52 PM   #6 (permalink)
Check for play in the bearing, grab the wheel and shake it, if it moves, put a new bearing in.
* Mike Garfias
Old 03-31-2005, 06:25 PM   #7 (permalink)
mine went 60,000 with a bunch of track miles.
Old 04-03-2005, 10:56 AM   #8 (permalink)
As DJ said, they wear out in about a year of hard track use. With the car up if you can feel a wobble in the wheel with it torqued down, they probably should be replaced.
But, not to worry, they won't fall off or seize if run past this. You just get more and more play in them. At some point it will start to impact your handling. When I can feel the play in the bearing, I can't tell on the track that there is a problem with the handling yet.
Old 04-03-2005, 11:13 AM   #9 (permalink)
I noticed pad taper on the one side before I could feel it by grabbing the wheel.
Old 04-04-2005, 09:05 AM   #10 (permalink)
You can also get ABS errors (along with TCS and AH) because the bearing is no longer sending good info to the computer. I will normally hear that tell-tale roar coming from a particular corner too.
Wheel Bearing Question II on 6 C5 Z06 - Pit Road 5 11-16-2006 07:22 PM
Shot wheel bearing? IndyDave C5 Z06 - Pit Road 2 11-21-2005 07:20 PM
Front Wheel Bearing Recommendations? racingfast C5 Z06 - Pit Road 16 05-22-2005 06:24 AM
Bad Rear Wheel Bearing?? Please Help. Cutlass476 C5 Z06 - Pit Road 5 01-03-2005 06:41 PM
Grease in the wheel KY-Z06 C5 Z06 - Grandstand 7 05-23-2003 03:38 AM
