Old 11-30-2005, 08:10 AM   #1 (permalink)
Wheel Hop
I know that all C5/C6 cars have the dreaded 'wheel hop' that can eat the differential quickly . . . any cure known? DTE does not work and the only thing I have found is much lower rear tire pressures and much easier launching.
Still, this is a poor excuse for what appears to be poor engineering - - my C4 stroker has a factory four link and it never hops.
Any suggestions? Thanks.
olddog is offline   Reply With Quote
Old 11-30-2005, 08:46 AM   #2 (permalink)
You should do a search, this topic has been covered many times, here is the short version:
1. Make sure tire pressures are factory
2. Check alignment
3. For the track, consider ET Streets
4. If (1) - (4) fail to solve the problem, install poly U bushings in rear suspension.
I had HORRIBLE wheel hop when the car was new, and I am an experienced racer. I tried 1-3, still had bad hop - went went the poly-u bushings, zero hop since.
Les
[sold] 02 QS Z06 383 c.i.
Old 11-30-2005, 09:21 AM   #3 (permalink)
Location: Edgewater, MD Z06 Fests 2,3,4,5,6,7 Ocean & WinterFest 1&2
Les
This is what was suggested to me to do, after making sure all the other items were in order. And if you are concerned of the ride, just replace the lower A-arm bushings with the poly units.
Good luck!!
NCM # 23306 Fest Member 2, 3, 4, 5, 6, 7 Ocean & WinterFest 1 & 2
Old 11-30-2005, 06:10 PM   #4 (permalink)
DJWorm's Avatar
Wheel hop is directly related to shock Rebound
For a street driven car get the '04 shocks
For a track car get Penske DA's
For a Drag car get the Penske DA's with drag valving
AMSOIL Online Store
Old 11-30-2005, 10:14 PM   #5 (permalink)
I had horrid hop on F1s. When I swapped to Toyo RA1s I got rid of it. With the installation of the polyurethane bushings, the hop came back.
Not nearly as bad, and on a cold road, but it was there. So I'm inclined to think that shocks could be a big part of it.
Of course, there is still a nasty fat ugly rubber bushing in the arm where the shock mounts (anyone make a replacement for this?).
* Mike Garfias
Wheel Hop olddog Racing 12 12-02-2005 10:16 AM
Wheel Hop??? MPRTKLR C5 Z06 - Pit Road 15 09-05-2005 07:49 PM
Wheel Hop ??????????????////////help R/ZO6-LS6 C5 Z06 - Pit Road 3 03-13-2004 01:39 PM
wheel hop raysutter C5 Z06 - Pit Road 6 11-26-2003 08:32 AM
Wheel Hop That Bad Man C5 Z06 - Pit Road 18 01-05-2003 05:33 PM
