Old 02-15-2004, 02:26 PM   #1 (permalink)
Will these tires Fit?
I am wondering if these nittos will fit my Z06?
they are 305/45 R18
http://www.discounttiredirect.com/di...odeIndex=40188
also does anyone else have these?
do you run them on the street?
How do they do 60ft times?
thanks
02 Black Z06 12.01@116
vipereater is offline   Reply With Quote
Old 02-15-2004, 03:10 PM   #2 (permalink)
I believe they will (might) physically fit. IMO that tire is way to tall.
The stock tire has a diameter of 26.1 the 305/45/18 has a diameter of 28.8 (That's huge). That would be like going from the stock gear ratio of 3.42 to a 3.07 gear ratio if my math is close to being correct. Which is going back-wards if your making the change for performance reasons. Also the sidewall height will be 1.3 inches taller and it will look strange (funny). A better choice would be BFG DR's in 315/30/18.
Old 02-15-2004, 05:51 PM   #3 (permalink)
MSiska's Avatar
I'm curious as to these tires being ok with a 3.90 rear? I have read in other posts that if you go up in the rear end ratio, you should get a taller tire. I wonder if these would throw any codes by keeping the stock diameter front tire and having these taller tires on the rear?
Old 02-17-2004, 07:24 AM   #4 (permalink)
MSiska's Avatar
anybody have any thoughts or opinions?
Old 02-17-2004, 11:51 AM   #5 (permalink)
In terms of codes I am unsure - but you would certainly get a bigger contact patch to the pavement with a taller tire. Most drag guys go with a taller tire and more gear for the best traction and quick acceleration/60ft times.
With the 3:90s you may need more tire to hook.
THRLSKR is offline   Reply With Quote
Old 02-17-2004, 02:53 PM   #6 (permalink)
That tall of a tire will change your 3.90's to a effective ratio in the 3.60's range
Old 03-02-2004, 05:06 PM   #7 (permalink)
If im not mistaken, these are made for the Ford Lightning and will NOT fit.
Been there, done that.
Turbo666 is offline   Reply With Quote
Old 03-02-2004, 05:18 PM   #8 (permalink)
RocketSled's Avatar
Go to:
Upgrading to larger Tires + Turning on the OEM Tire Pressure Monitor system
And most of your questions will be answered!
C6!
what tires will fit Rodney C5 Z06 - Pit Road 1 01-20-2006 01:54 PM
What aftermarket tires will fit the new Z? phantasms C6 Z06 - Pit Road 2 06-16-2005 04:28 PM
Need a set of tires to fit 18 x 9.5 and 19 x 11 ccajun4real Member Sales - Parts & Cars 0 09-02-2004 08:48 AM
WTB: Tires to fit 18 x 9.5 and 18 x 11 ccajun4real Member Sales - Parts & Cars 6 08-21-2004 11:26 PM
Biggest Tires that Will Fit?? Loud Silver Z C5 Z06 - Pit Road 8 07-28-2004 07:11 AM
