Old 09-21-2005, 12:53 AM   #1 (permalink)
Wilwood Calipers and speed bleeders
I've been using speed bleeders on my stock calipers for the last 2 years and really like them because I'm a 1 man shop, but I'm upgrading to Wilwood SL6 Calipers up front. Will the speed bleeders work with the new calipers? What size do I need?
Lancer033 is offline   Reply With Quote
Old 09-23-2005, 08:45 PM   #2 (permalink)
No, the SL6 uses two much smaller bleeders on each caliper. Lose the speedbleeders and get a pressure bleeder, much easier IMO.
Joe
My Garage
Old 09-24-2005, 07:20 AM   #3 (permalink)
Send a message via Yahoo to ghoffman
I just open the bleeders and gravity does the rest.
ghoffman is offline   Reply With Quote
Old 09-24-2005, 08:30 AM   #4 (permalink)
DJWorm's Avatar
Speedbleeders come in many different sizes and applications. They are not universal.
The Corvette caliper application will not fit Wilwood calipers.
Part # SB 1428 are made for all Wilwood calipers.
AMSOIL Online Store
Old 09-24-2005, 05:32 PM   #5 (permalink)
or if in a rush.
Keep an old can of half full fluid and put some fish tank hose from the bleeder and you can do it yourself. Just pump the pedal with the hose in the old fluid.
Old 10-05-2005, 10:41 PM   #6 (permalink)
Right, speedpup, after years of trying both "Push." Release" and gravity draining, I finally hit on cracking the bleeders and pushing the pedal myself. WHAT A RELIEF!!!!
Bob Rothwell
01 QS Z06
Old 10-06-2005, 05:39 PM   #7 (permalink)
After you do it you can count pumps and know about how much fluid was pumped. Don't let the master go dry.
Old 10-07-2005, 10:45 AM   #8 (permalink)
Trans.
Hey Pup !
Whats up with your trans ? Any diagnosis yet ?
Greg
BW Motorworks is offline   Reply With Quote
Old 10-08-2005, 11:20 AM   #9 (permalink)
3rd gear syncro cracked it is done and back together. No signs of heat in the tranny so the DRM cooler is working fine. Putting in upgraded dogs and fork. New third gear also which was rounded a tad. Probably from me jamming it with no syncro.
Old 01-04-2006, 11:33 AM   #10 (permalink)
EDIT: Disregard this info, I'm blind
Although it's been a while, I wanted to follow up on this post and correct some information found here.
The speedbleeder replacement for the stock calipers is part #SB1010 and on the Speed Bleeder site ***edited*** says that part # SB1428 is for all Wilwood Calipers.
I've got the LGM Wilwood kit that Wilwood SL6 full width calipers with stock rotors and the Stock size bleeders (#SB1010) fit perfectly while the 1428s are way too small.
I can post some pics if anyone needs them, but wanted to put that info out incase anyone else is looking to buy some bleeders.
Old 01-04-2006, 01:11 PM   #11 (permalink)
The speedbleeder replacement for the stock calipers is part #SB1010 and on the Speed Bleeder site says that part # SB1428 is for all Wilwood Calipers.
On the Wilwoods you have the insert in the caliper then the bleed screw. With the bigger one you may have replaced the insert no the bleed screw. Insert is easier to replace and will take the wear from constant bleeding. Just a guess.
Old 01-05-2006, 12:07 AM   #12 (permalink)
maybe i need to go back and take a better look at this
Old 01-05-2006, 10:18 AM   #13 (permalink)
John, thanks for the tip, i didn't even notice the 2 parts of the bleeders. The insert is the 1/4" size for SB1428, so Speed Bleeder and Wilwood were right and I was wrong. I guess it was going to happen sooner or later
Old 01-05-2006, 10:24 AM   #14 (permalink)
I AGREE
jjwvette is offline   Reply With Quote
Old 01-07-2006, 09:34 AM   #15 (permalink)
Originally Posted by BW Motorworks
Hey Pup !
Greg
Same thing happen at VIR after 140 miles rebuilt again They say it may be the clutch draging I have no clue. After driving the car for 58,000 miles on two different trannies now I can't go 150 Didn't decide on the clutch so I fixed the tranny again and drove it on the trailer. Now I am afraid to drive it at $2,000. a pop. May turn waxer Probably go with a 7.25" Quarter Master which will be super light weight.
Correct Tension for Speed Bleeders? SomeGuy604 C5 Z06 - Pit Road 12 06-27-2007 03:52 PM
Where to find Speed Bleeders raddad43 C5 Z06 - Pit Road 3 06-23-2005 11:30 AM
Speed Bleeders arrived..... jnjboc C5 Z06 - Pit Road 4 05-20-2005 08:21 AM
Got new Wilwood calipers for the front, should I use front Z06 calipers in back? Dr Chill Racing 10 12-27-2004 04:30 AM
Speed bleeders..who sells them?? Silver Bullet C5 Z06 - Grandstand 5 06-15-2001 09:57 AM
