Old 06-27-2009, 08:33 PM   #1 (permalink)
BOOOM!!!!!! Yup thats what she did tonight :(
BOOM! Well it appears something in the driveline went BOOM! I was going out to a local hangout on the highway and I accelerated in a clearing in 4th gear and as the rev's got higher it went BOOM and I was like oh **** I hit the rev limiter. Shifted into 5th gear, nothing just revved, put it in 6th and it revved, then almost every gear even 1st gear while going 40-50mph. So I drift to a stop and as i'm going F**K F**K etc etc you get the point. While sitting still with the engine running and revving it I could shift into all gears and the speedo wouldn't move no matter how much I revved the car. So trailered the car home and jacked it up. Turning the rear I can feel a rough spot, not a grinding but rougher. You can feel a difference when putting the car into gear with rolling the rear tires and hear the trans moving in gear. So the car is down, not sure what it is and REALLY REALLY NOT HAPPYE RIGHT NOW!!!!!
10sORBUST is offline   Reply With Quote
Old 06-27-2009, 08:50 PM   #2 (permalink)
Jim Lembo's Avatar
Re: BOOOM!!!!!! Yup thats what she did tonight :(
not a grinding butear rougher. You can feel a difference when putting the car into gear with rollinghe ring g the rear tires and hear the trans moving in gear. So the car is down, not sure what it is and REALLY REALLY NOT HAPPYE RIGHT NOW!!!!!
Bruce,
Sounds to me like a broken trans output shaft! Been there a couple of years ago,,,,,but mine was caused by a POS used DTE rear losing teeth off of the
ring gear and the broken teeth getting caught between the reluctor and the inside of the housing causing a sudden stoppage. Happened at Firebird raceway during HPDE at Winterfest 1 with my daughter Lauren driving the car.
Scared the crap out of her! I feel your pain bro!
Jimbo
sig by GR8 White
'03 EB/mod blue, LME/V-Max 416, AFR 225's, Comp Custom cam from Pete at V-Max, 3" custom exhaust and lots of attitude! 10.79@128.32 Z06 Fest member III, IV, V, VI, VII, VIII and Winterfests 1, 2 & 3. 543rwhp/493rwtq, all motor!
Jim Lembo is online now   Reply With Quote
Old 06-27-2009, 08:57 PM   #3 (permalink)
MikesZ06's Avatar
Originally Posted by Jim Lembo View Post
Bruce,
Vette Magazine article
1/4 mile pass
Old 06-27-2009, 09:13 PM   #4 (permalink)
AZZ061's Avatar
yep a shaft!@
SIG by GR8 WHITE
AZZ061 is offline   Reply With Quote
Old 06-28-2009, 04:48 AM   #5 (permalink)
FiveOJoe's Avatar
Sorry you broke. Is your car a C5 or C6? I was just wondering if the C6's break half shafts too?
FiveOJoe is online now   Reply With Quote
Old 06-28-2009, 05:51 AM   #6 (permalink)
Z0fritz's Avatar
That sounds exactly like what happened to mine last summer. Accelerated from 4th to 5th on an open black top and BOOM....no drive gears. Trailered it home, jacked it up...rolling the tires around I could hear a metalic cling, cling, cling, coming from what sounded like the rear of the torque tube. It ended up being a broken mainshaft (trans output). Broke off at an angle about the last 3 inches of the shaft...new transmission and new differential...went ahead and put in new drive shaft couplers while I was at it...rear aluminum/front rubber.
2003 Yellow Z06: Comp Cam, TI retainers, Halltech Venom, SVO 30# inj, Water/Meth injection, Katech ported TB, TB bypass, underdrive pulley, Kooks LT, BB bullet exh, No cats, RPM trans/diff 3.90, exedy twin disc, BPP shifter, dyno tuned...etc...
1969 Mach 1 big block being restored
Z0fritz is offline   Reply With Quote
Old 06-28-2009, 08:08 AM   #7 (permalink)
UVETTYA's Avatar
Location: Phoenix, Arizona Winterfest I, II and III, Z06 Fest VII
I'm sorry to hear that. I've certainly had my share of drive line issues, so I feel your pain. Counting stock parts my Z has seen 4 tranny's, 3 diff's and 3 clutches. I'm thinking of just installing quick disconnects everywhere...
I know you're feeling down now but look on the brighter side... you can go with 373 gears and hardened shafts.
Steve
Black '04 Z06
UVETTYA is offline   Reply With Quote
Old 06-28-2009, 08:41 AM   #8 (permalink)
If i had to I'd go 3.90s :( If you come up with ANYTHING ON THE QUICK DISCONNECT LET ME KNOW!!!!!!! I'LL SPONSOR YOU!!!!!!!!AND BE YOUR TEST DUMMIE! If we could just get the car to be half as easy as my Fbody was to take things apart. You can have the clutch out in 1.5hours by yourself, same for rear or trans or almost all in 3hours. Even the cam jobs are kindergarden material in comparison to these damn corvettes!!! I love my car but hate working on it.
Old 06-28-2009, 10:31 AM   #9 (permalink)
2MchFun's Avatar
Bummer! That sucks - especially when you're not even at the track beating on it. Best thing to do is look at it as an opportunity to make it better than it was Good luck with the diagnosis & rebuild.
'04 MS/Blk - Z06Fest IV, V, VI, VII & VIII - WinterFest I "Bus Driver"
Old 06-29-2009, 04:27 AM   #10 (permalink)
I'm not totally convinced of the trans output shaft yet. How the heck can I shift the trans mission revving the car NOT USING THE CLUTCH AT ALL???? There should still be some binding of the transmission going from gear to gear with the tranny spinning at different RPM's not using the clutch?
Old 06-29-2009, 05:59 AM   #11 (permalink)
What a great attitude!
Old 06-29-2009, 06:32 AM   #12 (permalink)
UVETTYA's Avatar
John, I actually cried when 3rd gear started grinding on my 3rd transmission, after babying it for 700 miles so it would have a good break-in period. I figured I would get more than 700 miles out of it. I was wrong. The other two trannies died because Mike O'bozo sent me out of his shop with no oil in them. Yes, twice. So I'm used to disappointment. I can laugh or I can cry, it's up to me.
BTW, correct me if I'm wrong but I think it was Benjamin Franklin who said God gave us beer to keep us happy. :mug:
Old 06-29-2009, 06:56 AM   #13 (permalink)
I think the Benjamin quote was "Beer is proof God loves us". Or something like that. I"m sure Pittman will know the answer!
Old 06-29-2009, 07:16 AM   #14 (permalink)
UVETTYA's Avatar
I think we're both right. The actual quote is: "Beer is proof that God loves us, and wants us to be happy." -Benjamin Franklin
Old 06-29-2009, 03:32 PM   #15 (permalink)
Thank God for beer and babes!
Jub Jub
Rate This Thread:
Yup another HID question. blown 346 C5 Z06 - Pit Road 16 12-25-2006 11:03 PM
Yup, I'm bored... Started Polishing LG's SIINSI The Garage (non Vette related) 18 12-03-2005 07:48 AM
Just ordered 6 Nittos, yup I said 6 LS6NickM C5 Z06 - Pit Road 3 01-07-2005 04:42 PM
Yup, my baby has to work also... PerforminNorman C5 Z06 - Grandstand 3 03-06-2002 09:51 AM
BOOOM - Uh Oh!!! J-Rod The Garage (non Vette related) 15 02-26-2002 06:21 PM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
