Old 11-21-2007, 04:38 PM   #1 (permalink)
Clutch\Power Shift...NOT
Ernie,
you are right (I hope)...did some testing today and it seems the pedal has to hit the floor (as Robz does) before it will pull a clean shift. I know I wasn't deep throwing (ha) the pedal Saturday. I ordered the new adjustible McLeod yesterday...hope that is the trick. I have never had to hit the floor in any of my other cars (cannot get used to it) and I think your pedal block idea might work with the new Master. Actually, Unless you hit the floor,
it really doesn't shift smooth anymore. Might be changing another clutch...will be another brand for sure. Only about 900 miles on this one and 15 runs at the track. Grip is great, but total dis-engagement has an issue. That is 2 from same company now in less than 12 months. Might try a Tex for the next unless someone tells me different. Keep ya posted..Pit-man
2003 Z06 - 1.48 sixty foot , 383 Stroker NA, AFR 225's, Fast, Vararam, LG Longs, 390 Gear, thru stock mufflers. Best eighth 7.14, Best quarter 11.122 @ 125.49, 2800 DA & 83 degrees
Pit Man is online now   Reply With Quote
Old 11-23-2007, 02:41 PM   #2 (permalink)
Ernie King's Avatar
Re: Clutch\Power Shift...NOT
Pit,, I don't think you will need a stop with that Master Cylinder.. you will be able to adjust it where you want.. But don't forget it Will make it harder to push down, but not to bad.
Keep me posted...
Ernie
2000 FRC Nassau Blue
10 Second Club
Rate This Thread:
how much power on a stock clutch? slp223 C6 Z06 - Pit Road 5 05-19-2006 12:00 AM
Shift points and power quickSS Racing 2 12-09-2003 07:09 PM
How do you power shift, is J-Rod around? 427l Racing 3 05-24-2003 08:47 AM
Too much power for stock clutch, Help me out!!! SteveYelloZ06 C5 Z06 - Pit Road 4 05-12-2003 10:49 AM
Shift Lights... and Power Sourcez? Zed C5 Z06 - Pit Road 2 02-26-2003 09:57 PM
