Old 02-20-2008, 04:46 PM   #1 (permalink)
sean67's Avatar
What to expect on 1/8 miles times
Hello:
I am finally taking my Z to the local track on test and tune day this Saturday. I have a bone stock (minus shifter) '02. The last time I ran this track my car at the time had a little trouble hooking up, but overall it is a decent track. Weather should be in 50's to low 60's.
Assuming some bad driving on my part, should I expect low to mid 8's? My last car would do 8 flat and low 12's in the quarter on street radials and the Z feels about as fast. What should I expect?
Thanks for any feedback.
Sean
Sean Moore
sean67 is offline   Reply With Quote
Old 02-20-2008, 04:49 PM   #2 (permalink)
wvphoto's Avatar
Re: What to expect on 1/8 miles times
tires make a difference..
i am NOT a drag racer.
with stock tires 1/8 th i would run mid 8's
with drag radials real close to 8
i am not much on the launch and 60 f
but it was fun.. the z is just starting to run strong on the 3 rd shift.. and the ride was over.
its fun
just stay off the wall !!! get squirly.. LIFT
ZFest Member I II III IV V VI
more to come
RIP speedratchet * see you at next years fest *
Old 02-21-2008, 08:09 AM   #3 (permalink)
Originally Posted by sean67 View Post
Hello:
Sean
Probably about the same IMO....Low 8's and mid 12 1/4 mile unless your a great driver. That's still fast !!
Pit
2003 Z06 - 1.48 sixty foot , 383 Stroker NA, AFR 225's, Fast, Vararam, LG Longs, 390 Gear, Best mph 125, Best eighth 7.15 @ 99 mph, Best quarter 11.28 (w\lots of spin)
http://s160.photobucket.com/albums/t...t=Run1-383.flv
http://s160.photobucket.com/albums/t...t=Run2-383.flv
Pit Man is offline   Reply With Quote
Old 02-21-2008, 04:40 PM   #4 (permalink)
sean67's Avatar
Thanks. That is about what I was expecting, or expect. Just so I beat my buddy in his Crossfire SRT (he is doing 8.60's) all will be fine.
If the numbers are decent I will post them Saturday. If not then I will be either practicing more or buying some goodies to make up for my driving skills.
Sean
Old 02-21-2008, 05:32 PM   #5 (permalink)
Just start around 2200 rpm, let the clutch out pretty fast and slowly press the peddle to the floor..(not too slow..like a quick one-two-three). Drop your air down to about 18-20 maybe in the rear and air up the front to 44 psi. Then just see what happens. If it bogs, come out a little harder till it pulls thru. That always gave me mid 12's if I didn't miss a gear or hit the gas too hard and spin. Let us know how you did.
Pit
Old 02-22-2008, 06:19 PM   #6 (permalink)
Sean, look up a couple threads and you will see Rangers Launch info..he is better at this than me !!
Pit
Old 02-23-2008, 03:31 PM   #7 (permalink)
sean67's Avatar
Thanks for information.
I just got back and ran a very slick 8.5 @ 89.7 mph. I was really bad. I used to go to the drag strip at least once a month but that was 15 years ago. I need to practice as the torque/clutch gave me a fit.
I only made two passes and the second one started with bad wheel hop and the activ hadling taking over and me lifting when I got sideways when I hit third.
I had a blast though. My buddy turned an 8.5 with his SRT, that was very impressive to me. Oh well, now I know. 1/8 seems to short though but still good to get out to the track.
Thanks for the help.
Sean
Old 02-23-2008, 08:01 PM   #8 (permalink)
Sean
Sean,
Guess you are still on street tires huh ? Did you remember to turn on the Competitive mode on at least one run ?
Pit
Old 02-24-2008, 11:22 AM   #9 (permalink)
sean67's Avatar
Pit,
Oh yeah, just the Firehawks. Had the competition mode on. The sideways in third surprised me. I got what I thought I would/could. I amy go back later and practice when it gets warmer. I think I can get a couple of tenths off my time. The car definitely needs some street slicks to really see what it can really do. That and a better driver.
Old 02-27-2008, 03:21 PM   #10 (permalink)
sean67:
Looks like you had a decent first time out in your Z. I'm pretty sure your street tire times are better than mine were, before I got ahold of some used MT ET Streets 26x11.5x16 on Trans-Am wheels.
With them, I ran a personal best in my 98% stock 01 Z06 just a couple weeks ago at Barona drag strip, east of San Diego.
60': 1.799
ET: 8.022
MPH: 88.639
Only changes from stock:
K&N drop-in filter in the stock airbox (lid removed); MAF screen removed; fuel cutoff raised to 7000; "No-Lift-To-Shift" = 5500rpm fuel cutoff when not in gear/clutch depressed.
Oh yeah, I always run in Comp Mode, too. It really sucks when you forget to turn off the TC! (should get a LapTraxx, I guess...)
c5_4_me is offline   Reply With Quote
Rate This Thread:
Stroked/forged How many miles can we expect???? dbvettez061 C5 Z06 - Forced Induction & Nitrous 5 09-14-2005 06:22 AM
What kind of power and times can I expect from these mods? DanielW C5 Z06 - Pit Road 9 09-08-2005 07:42 AM
What AFR can I expect jdk C5 Z06 - Pit Road 5 05-23-2004 08:21 AM
What is the fastest stock 1/4 miles times? 427l Racing 15 02-12-2003 11:14 PM
What to expect gammara C5 Z06 - Grandstand 2 06-12-2002 01:52 PM
