Originally Posted by dgoetz
The machine screen did show -2.4 caster but printed 2.5, I figured that it must be like 2.46 or something.
I think you mean camber, not caster.
Personally, I've found that straight line steering and braking are fairly insensitve to caster so that is the alignment spec I least prioritize.
I've also found that as the front lower a-arm's slide after on their bushings over time, it gets harder and harder to get max negative caster. I've also found that to get that much negative camber makes it hard to get a lot of positive caster given the orientation of the lower front a-arm.
All that said, I can get caster matched to within a few tenths in my garage using hand held tools. What I would do if I had your alignment specs is take some caster out of the right side to get it close to the left. This will also drop the camber on the RF, so that would need to be tweaked back in. End result, they should be able to get camber about -2.4 and caster about 4.8 on both sides.
