Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > Racing > Autocross
Old 03-17-2008, 07:45 PM   #1 (permalink)
does lowering past stock affect "Bilstein Sport" shock performance?
I'm considering lowering the rear about 1/2 inch below stock and have new Bilstein Sport shocks all round.
Does this affect the performance of the shock?
Does it upset the balance between front/rear.
Purpose of car is very spirited autocrossing in NCCC events.
D
dfootdoc is offline   Reply With Quote
Old 03-17-2008, 07:47 PM   #2 (permalink)
Re: does lowering past stock affect "Bilstein Sport" shock performance?
...on a 02 ZO6 that is...
Old 03-17-2008, 07:57 PM   #3 (permalink)
No, lowering in the rear will just increase your rear grip.
Be careful not to go too low, as the car will bottom out & your rear end cornering grip will be greatly compromised.
George B.
* '08 JSB Z06 11.4 @ 126 on EMTs, 481/454 SAE #s--some bolt-ons...
* '90 ZR-1 SGC built 368ci 'Factory Black Motor' (11.0 @ 130.2 & 11.2 @ 132.4) w/ the 368 (421ci Stroker coming!)--sprayed 120 shot.. 448 RWHP on motor, 560+ RWHP on the spray (SAE #'s)
Old 03-19-2008, 02:43 PM   #4 (permalink)
Bottoming out should be less of an issue with the Bilsteins than with OEM shocks. Next to my stockers, the Sports which I installed were roughly 1/2" shorter overall.
Old 03-25-2008, 05:23 PM   #5 (permalink)
DJWorm's Avatar
The Bilsteins will accept lowering to max using the stock hardware better than the OEM shocks. If you lower further using longer rear spring perch bolts then you will need shorter shaft and body shocks.
You CAN lower just the rear IF you maintain at least 1/2" Rake. Ie the front 1/2" lower than the rear. That is the optimum Rake for AutoX and minimum you should go.
AMSOIL Online Store
Old 04-02-2008, 12:03 PM   #6 (permalink)
What reference points should be used for measuring rake? Wheel arches? Rocker panels?
Old 04-04-2008, 09:39 AM   #7 (permalink)
Thanks DJ. I didn't lower the car anyfurther. rake is set.
The car certainly is more stable on rough surfaces and acute elevation changes. for ex. there is a significant bump during a high speed turn on our local track that really upsets the chasis and the bilsteins are superior in keeping the car balanced through this area. definite improvement!
Rate This Thread:
Hey "UR2SLOW", I walked past your car today in Gaithersburg Chris Holmes C5 Z06 - Grandstand 1 10-31-2005 08:54 AM
Is "good" customer service a thing of the past? PerforminNorman The Garage 21 01-27-2005 08:17 PM
2004 Z06 Shock versus Bilstein Sport TooManyIDs C5 Z06 - Pit Road 17 10-28-2004 09:25 PM
Check out my new "Grand Sport" style wheels! BIG LAW MAN C5 Z06 - Pit Road 28 08-16-2003 12:12 PM
Bilstein Z06 Sport Shock and Hotchkis Z06 Sway Bar Package Deal Going on NOW!! L.A. Performance Division Vendor Sales - C5 3 02-20-2001 06:05 AM
