Gp II
Stock sway bars for class OK
Any diameter sway bar allowed. May be Heim jointed. May have adjustable sway bar end links. OK
Factory or aftermarket adjustable spring of correct configuration for year group - C5-newer. Modify/remove spring mounting pads. OK
Go to the NCCC web site and you can check the table in Chapter 2.
I can't take credit for the suggestion attributed to me, but I'm inclined to agree with it ...
I think you really want to keep four contact patches working through turns and transition s...
I am NOT a suspension engineer ... but what I understand from what I've read ...
I would first go to poly bushings ... so that the alignment set is more consistent thru suspension loading, unloading, loading.
This isn't rocket science. ... but it's close ...
The leaf spring and the sway bar work in parallel. ... and the shocks need to be matched to the spring and bar ... and you can't run adjustable shocks in GP II ...
For AutoX the roll transition is desireable ... where permitted, sometimes guys even disconnect the rear sway bar.
For road course, roll resistance is important ... thus the T-1 bar.
Ask the suspension engineers what they think of increasing spring rate and leaving sway bars stock for autox ... works to keep the car flatter and still maintains transition ...
FWIW ...
