Old 08-04-2008, 04:47 PM   #16 (permalink)
Re: Frequency of trans/diff fluid changes for tracked cars?
I blew my automatic in about 5,000 miles doing autocross and burnout competitions. Didn't even have a chance to change the fluid! LOL
1997 Chevy Camaro SS M6 - Polo Green, Blown 383
2006 GTO A4 - Spice Red - Cam, Heads, Headers
2006 Saab 9-7X Aero (LS2) - Black, Stock....DD!
2008 Z06 - Stock at the moment.
ls2gto06 is offline   Reply With Quote
Old 08-04-2008, 08:18 PM   #17 (permalink)
blkZ06's Avatar
Originally Posted by WB6HRO View Post
Denny,
I am running the same DRM ducts and Phoenix spindle mounts. I also have the DRM SS pistons. The R4 pads wear very well and do not wear the rotors. I can do 25-30 events before I change rotors (Napa's), the pads usually last about 10-15 events.
I like changing the piston seals when I change pads they do get hot and since I do a lot of late braking to pass C-6 Z06's, it's cheap insurance. The seal kits are about $12 each.
I melt the dust boots and asked DRM about it. They said that it was normal, they don't even put the dust boots on with the SS pistons.
holy cow batman! I am lucky to get 2 wknds outta my Napa rotors!
I change out the diff and tranny every spring, bleed brakes before every track event
Old 08-08-2008, 02:05 PM   #18 (permalink)
WB6HRO's Avatar
OK here is the info on the R4 compound.
R-4 Full Race Compound – Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at very even rate. Carbon Kevlar material warms up to race temperature quickly, which is quite helpful during restarts, and when track time is limited. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the carbon kevlar material will give extremely consistent modulation and predictably. This is truly the most rotor friendly racing brake pad material ever. Good for road courses, oval track, rally, vintage racing, autocross, club events or professional racing events.
Joe Orrico
2002 Z06 Built 10/30/01 R8C 11/13/01
Kuhmo 710
WB6HRO is offline   Reply With Quote
Rate This Thread:
Diff or Trans Cooler? 99cobra Racing 8 02-15-2005 09:53 PM
Trans and Diff Cooler Install Info 405HP_Z06 Racing 3 02-07-2005 06:35 AM
Question for trans/diff cooler users dmtnt C5 Z06 - Pit Road 2 10-10-2004 02:36 PM
QUICK HELP PLEASE--trans/diff leak gbjerke C5 Z06 - Pit Road 5 09-08-2004 09:40 PM
Magnetic drain plug: trans & diff?? BrianK C5 Z06 - Pit Road 2 11-26-2001 11:16 PM
