Old 12-12-2007, 07:35 AM   #31 (permalink)
BEZ06's Avatar
Re: HPDE Checklist
Great checklist!!!
I used most all of it for my first HPDE last weekend at Daytona.
After the Friday sessions I decided I needed a checklist to remind me what to do to get the car ready just before taking the track. I've got a C6 Z06 with all the options, and some of that fancy stuff can mess you up if you shut the car down on the grid/staging lane.
On my first solo session Friday afternoon I got the car all set in the paddock and pulled out onto the pit lane where we staged. The car was all warmed up and ready to go, but we still had 7 or 8 minutes until the track was clear and my group would be going out, so I shut off the engine and opened the door to try and keep cool (it was almost 80 degrees), took off my gloves, and released my seat belt to swing my feet out for a couple minutes. When I did that the car goes to my memory "exit" settings (seat goes back and down, steering wheel moves in, etc.).
When the previous group was pitting after their cool down lap I started the car up. This being my first HPDE I was mostly thinking about the track, and when I pushed in the clutch I could tell my seat and the steering wheel weren't quite right. I quickly pushed the memory button to go to my preset stuff, but in addition to seats and mirrors, that also sets the HUD, radio, air conditioning, etc. to my street driving setup I had programmed, and it resets AH/TC to full on. I was scrambling to get set just before pulling out onto the track.
The same thing happened for a couple other sessions, but with my checklist I knew I was ready to hit the track and wouldn't be distracted by something I forgot to set up properly.
Beginning Track Session
• Memory Button – #1
• HUD – Track Mode
• AH – Off or Comp Mode
• NPP Valves – Open
• Radio/Nav – OFF
• Air Cond – OFF
• Seat Belt – Ratchet tight
• DRL’s – OFF
Hitting the memory button gets the seat/mirrors/steering wheel where I want them. But it calls up my memorized street HUD mode, so I need to select the track mode I want.
I started out with full AH on, but during the first few sessions I could see the DIC flashing that it was active a couple of places on the track where I didn't want it. I went with Comp mode after that - it still came on when up on the high banked wall at about 140 or 145 (it's kinda bumpy up there! ), but I figured it was doing something for me that I wasn't aware of at my low experience level.
I've got a Mild-to-Wild wireless controller for my exhaust butterflies, and just opened them up before taking the track. They'll open above 3,000 rpm in Comp mode anyway (so probably would have been open the whole time on the track anyway), but I just opened them so they wouldn't be cycling.
I've just got the regular OE seat belts, but if you pull them all the way out they will go into a "ratchet" mode. That way I could pull it real tight and it helped keep me fastened to the seat a little better.
I decided I wanted to run with the DRL's off, so I turned them off manually.
Bob
BEZ06 is offline   Reply With Quote
Old 12-12-2007, 10:27 AM   #32 (permalink)
DennyM's Avatar
Re: HPDE Checklist
Originally Posted by BEZ06 View Post
[b]Beginning Track Session
Bob
Bob ... If I missed you earlier, ... welcome to
excellent post ...
I use the third memory position (push 1&2 together) and use that for my track setting ... that way I don't have to mess with the other settings ...
I think you have the same function as the C5 (certainly no less!)
BTW ... check in here for thread coming up on NCM VIR HPDE end of Jun
Old 12-12-2007, 01:17 PM   #33 (permalink)
BEZ06's Avatar
Re: HPDE Checklist
Denny
Thanks for the welcome!
I should (will!) post a "checking aboard" message in the General section. I've been lurking since I got my C6 Z06 2 months ago, but I've only made a couple of posts.
Thanks for the heads up on the 3rd memory position. I've had a 2005 C6 for 3 years now and I've never heard of that capability on the C6, but I'll have to check it out.
Tom B (Au N EGL on another board) has already got my attention about the VIR and RA events by the NCM. I definitely plan on the VIR event, but Tom said the event this year filled up in 1 hour and 45 minutes when registration was opened up this January!!!
I plan to put it in my calendar and set an alarm on my cellphone when registration time gets closer.
Bob
Old 12-12-2007, 03:46 PM   #34 (permalink)
DennyM's Avatar
Re: HPDE Checklist
Bob
I started a thread here:
NCM HPDE Schedule for 2008
I'll post up in Jan, before the NCM site opens for registration ...
Old 12-23-2007, 04:38 PM   #35 (permalink)
Re: HPDE Checklist
This is a great checklist, lots of good details. How about adding a checklist for things to recheck while at the track, before each run...
1) tire pressure
2) torque lugs
3) fuel
etc..
It's amazing to me how many people (myself included every once in a while) who get caught up talking with everyone that before they know it is their time to run again and don't take/make the time to recheck everything before heading back out.
Texas Z06 is offline   Reply With Quote
Old 07-18-2008, 10:06 PM   #36 (permalink)
Re: HPDE Checklist
- fresh change of underwear.
Sorry, that's on my "private" list.. Thanks for the great stuff everyone.
Rate This Thread:
NASA HPDE Southeast Time Trial Shootout Idea..all HPDE and racers weigh in Silver Bullet Southeast 7 08-07-2005 02:47 PM
DE Checklist - Results ack.Z06 C5 Z06 - Pit Road 1 07-16-2004 04:05 AM
DE Checklist ack.Z06 C5 Z06 - Pit Road 20 07-10-2004 06:39 PM
Delivery Checklist 2002 Z my 6 C5 Z06 - Grandstand 1 09-05-2001 07:52 PM
