Old 09-30-2008, 09:00 PM   #1 (permalink)
stock brake pad life
Well I've got 6000 hwy miles and 2 track events on the stock brake pads. Got paranoid so I checked...I pulled the R side wheels and checked the pad left:
outer pad (less there than inner) thickness front 4mm, rear 6.5mm..
That's 0.16in / 0.25in
This is plenty based upon the manual (0.03in min)..
So they should last a few more events. Any comments on wear and at what thickness to replace (yes, assuming I don't want to upgrade sooner)..
08 stock Z
Old 10-01-2008, 09:54 AM   #2 (permalink)
DennyM's Avatar
Re: stock brake pad life
Conventional wisdom for track prep is to replace the pads when they get below 1/3 of original thickness. The last third goes faster; more heat is transferred to the pistons and thus fluid. I'd say put new fronts on. If you don't run with AH on, the rears should be OK> If you do run with "all on", might swap the rears as well.
Keep your take-off's around for contingency spares.
If you're going to be tracking regularly, ... may look into one-piece pads ...
Old 10-08-2008, 07:40 PM   #3 (permalink)
AlohaC5's Avatar
Send a message via MSN to AlohaC5
Great advice!
AlohaC5 is offline   Reply With Quote
Rate This Thread:
C6z Brake Pad Life defender The Garage 0 10-09-2007 09:46 AM
Stock Brake Pad Life? Bob C5 Z06 - Pit Road 14 01-05-2006 12:09 AM
Brake Pad Life Black Jack C5 Z06 - Pit Road 4 12-15-2004 08:55 AM
Brake Pad Life Span JoeNBlu C5 Z06 - Pit Road 2 04-03-2003 09:27 PM
Rear brake pad life Dean Robinson C5 Z06 - Pit Road 3 05-06-2002 07:34 AM
