Old 07-03-2008, 07:00 PM   #16 (permalink)
BEZ06's Avatar
Re: Daft second wheel set price.....
Originally Posted by Leman View Post
I have just been made an offer of wait for it... $12'000 for a set of OEM competition Gray wheels and Michelins.....
How much and where can I get a race ECM and what other surprises does it pack??
I use nitrogen as well, works well. And no leaks!
Hi Dimitri
Do an internet search for "Motec" and you'll find info about a race ECM.
I just finished my 2nd track event - we did VIR (Virginia Intl Raceway) and I really learned a lot!!! Here's a link to a couple laps of video. Go easy on me - it was just my second event on the track and first time at VIR.
YouTube - 2 Laps at VIR
Bob
BEZ06 is offline   Reply With Quote
Old 07-03-2008, 07:13 PM   #17 (permalink)
Re: TPMS racing defeat
A Motec engine management system by itself (or any other replacement PCM) will not, by themselves, disable the TPMS system.
Once again, the TPMS system is a function of the RCDLR and BCM in conjunction with the IPC.
As I said above, you can use a Tech 2 and re-program the RCDLR module itself in order to use different tire pressures. The car will then allow that new range of pressures. It has nothing to do with the PCM.
Other than being on the system BUS, the modules involved with the TPMS have nothing to do with the PCM. You can disable the TPMS by removing the modules mentioned, without touching the PCM. However, this will interfere with other operations and is not something one would want to do on an otherwise stock street car.
Simply put, replacing the PCM alone will not disable the TPMS.
Old 07-04-2008, 11:57 AM   #18 (permalink)
BEZ06's Avatar
Like No Doubt says above, you really can't get rid of the RCDLR and BCM on a street car - you won't be able to raise or lower windows, you'll have to pull your mechanical door release to open the doors, probably won't even be able to turn the headlights on and off. EVERYTHING is computerized on the C6!!!
I talked with a team that had a race-prepped C6 at an HPDE at Daytona last year. They said they had removed everything, but were still running a factory PCM and EBCM (Electronic Brake Control Module for the ABS). They had a full cage with the passenger seat removed. Their Coolsuit cooler box/thermos was secured to the floor where the passenger seat had been, and on top of that they had a Fob attached with industrial strength velcro!! So.....if you're running a factory PCM you're apparently still going to need a Fob to get the car started.
The other day at the VIR HPDE I checked out several full-race C6's. One had every factory computer removed except the EBCM. He was running a Motec so had done away with the requirement for a Fob.
Of course these race-prepped cars have no side windows and you either need to reach in and pull the mechanical door release down on the floor or a couple had cables run up to the halo for emergency crews to access the cockpit.
Like No Doubt said - not something you can do to a car and still be able to drive it on the street!
As long as the RCDLR and BCM are in the car you're going to have the TPMS to deal with.
Actually, one well known shop that prepares race cars was talking on another forum about reprogramming the BCM to do away with the TPMS. They were wondering how many owners would like to do away with it - if enough were interested they would hire a computer whiz and try to break into the proprietary GM code to rewrite it. They figured $20,000 to hire somebody, then they could provide new BCM units for maybe $1,500. They also said it would probably cost in the neighborhood of $1,000 to replace the BCM. I haven't heard any news lately.
Congress passed a federal law several years ago that required as of last September with the 2008 model year, ALL 4-wheeled vehicles less than 10,000 lbs MUST have tire pressure sensors and a TPMS. I guess it's sorta like running with no Cats in a non-emission state - nobody will probably ever know if you don't have them, but it is federal law that you are supposed to have Cats and sensors on a street car.
Bob
Old 07-17-2008, 04:39 PM   #19 (permalink)
So, after reading all of the above...Don't dummy TPMS sensors sound like the best option?
They would simply send a signal of 32psi to the car at all times (and speed and such) regardless of the tire pressure or lack thereof.
Please, steal my idea, and patent it, then send me the first 4 you make.
Rate This Thread:
Which cags defeat to get froggy47 C5 Z06 - Pit Road 10 12-24-2006 03:12 PM
Any new info on Track Tires/TPMS situation? quickZ C6 Z06 - Pit Road 1 12-28-2005 08:56 AM
CAGS Defeat - I wonder LoneRegister C5 Z06 - Grandstand 6 03-26-2004 09:45 PM
No need for a cags defeat Corvette Junkie C5 Z06 - Grandstand 7 01-10-2003 10:45 PM
03 CAGS defeat Dale S. C5 Z06 - Pit Road 11 10-30-2002 09:09 PM
