Go Back   Z06Vette.com - Corvette Z06 Forum > Supporting Vendors > C66 Racing LLC - AMSOIL Direct Dealer
Old 01-13-2008, 01:07 PM   #1 (permalink)
AMSOIL Releases Series 500 (DOT3) and Series 600 (DOT4) Brake Fluid
AMSOIL recently released two formulations of high performance brake fluid:
AMSOIL Series 500 High Performance DOT 3 Brake Fluid
AMSOIL Series 600 DOT 4 Racing Brake Fluid
AMSOIL Series 500 High-Performance DOT 3 Brake Fluid has a dry ERBP of 525°F and wet ERBP of 313°F, which far exceeds DOT 3 requirements of 401F (dry) and 284F (wet). The Series 500 DOT 3 Brake Fluid is recommended by AMSOIL for C5 and C6 Z06s. If my car was a daily driver (and/or under warranty), I'd use this fluid. I do intend on ordering a case for all my other daily drivers.
AMSOIL Series 600 DOT 4 Racing Brake Fluid has a dry ERBP of 580°F and wet ERBP of 410°F, which compares very favorably to other racing brake fluids such as ATE Super Blue which is 536F (dry) and 388F (wet). I will order a case of this and use it in my track use only 2002 C5 Z06 this season.
Subdriver is online now   Reply With Quote
Old 01-14-2008, 11:05 AM   #2 (permalink)
I may go ahead and try this when I need more fluid. Thanks.
Old 01-14-2008, 12:23 PM   #3 (permalink)
Location: Edgewater, MD Z06 Fests 2,3,4,5,6,7 Ocean & WinterFest 1&2
Re: AMSOIL Releases Series 500 (DOT3) and Series 600 (DOT4) Brake Fluid
Thanks for the info Brad....I'll add a container to my next order for sure.
Just in time for the new brakes on the RS project.
NCM # 23306 Fest Member 2, 3, 4, 5, 6, 7 Ocean & WinterFest 1 & 2
Rate This Thread:
AMSOIL Signature Series Synthetic 0w30 Subdriver C66 Racing LLC - AMSOIL Direct Dealer 2 01-13-2008 08:09 PM
For the C4 Owners: AMSOIL Releases Synthetic Synchromesh Transmission Fluid (5w30) Subdriver Vendor Sales - C5 0 06-06-2005 06:45 PM
Why DOT3 Instead of DOT4 Brake Fluid? ROSSO Z C5 Z06 - Pit Road 1 05-10-2004 04:11 PM
What's the Best DOT3 Brake Fluid? ROSSO Z C5 Z06 - Pit Road 7 05-17-2003 04:00 PM
Brake fluid - Ford Super DOT4 okay to use? Redshift C5 Z06 - Pit Road 4 07-03-2001 04:57 PM
