Go Back   Z06Vette.com - Corvette Z06 Forum > Supporting Vendors > C66 Racing LLC - AMSOIL Direct Dealer
Old 05-04-2008, 09:00 PM   #1 (permalink)
LS2 CTS-V Used Oil Analysis - AMSOIL 0w30 vs Mobil 1 5w30
I recently got back my used oil analysis from Blackstone Labs from my initial use of the now discontinued AMSOIL Series 2000 0w30 in my 06 CTS-V daily driver. The Series 2000 0w30 was replaced by the AMSOIL Signature Series Synthetic 0w30 which I plan to switch to on my next oil change.
For those interested in seeing how the AMSOIL performed as compared to my previous analysis using the factory fill Mobil 1 5w30, here is the data:
Cadillac CTS-V Used Oil Analysis – Mobil 1 5w30 vs AMSOIL 0w30
Subdriver is online now   Reply With Quote
Old 05-05-2008, 06:27 AM   #2 (permalink)
dwjZ06's Avatar
Re: LS CTS-V Used Oil Analysis - AMSOIL 0w30 vs Mobil 1 5w30
Brad,
Thanks for sharing the reports. Good info. Don
SIG by GR8 WHITE
Old 05-05-2008, 07:28 AM   #3 (permalink)
Could you maybe sum it up for us so we get the idea without having to go to another website and read the whole report? Thanks!
2007 MSM 2LZ Nav
jswatek1 is offline   Reply With Quote
Old 05-05-2008, 07:49 AM   #4 (permalink)
1st Column AMSOIL Series 2000 0w30/Oil Filter EAO32 3300 miles 3/8/08
2nd Column Mobil 1 5w30/AC Delco PF46 2856 miles 6/10/07
3rd Column Universal Lab Averages
Oil Life Monitor read 25% for both oil changes
Engine had 13,936 miles after the AMSOIL sample.
ppm ppm ppm
Aluminum 4 5 4
Chromium 1 1 1
Iron 20 26 24
Copper 76 139 107
Lead 6 10 9
Tin 0 1 1
Molybdenum 12 66 86
Nickel 1 1 1
Manganese 72 66 4
Silver 0 0 0
Titanium 0 0 0
Potassium 1 2 2
Boron 11 26 49
Silicon 18 26 17
Sodium 7 4 6
Calcium 3193 2588 2393
Magnesium 12 14 32
Phosphorus 634 661 652
Zinc 733 841 818
Barium 1 0 0
TBN 4.6 3.6 Min 1.0
SUS Viscosity @ 210F 58.8 59.8 Range ~55-66
cSt Viscosity at 212F 9.87 10.15 Range ~9.1-11.6
Insolubles 1.3% 0.3% <0.6%
Primary wear metals are Aluminum, Iron, Copper and Lead. AMSOIL showed lower wear numbers for all of these, but some of this can be attributed to engine break-in. AMSOIL's Total Base Number or TBN was higher at 4.6 vs 3.6 for the Mobil 1 showing more life left. Both remained in grade for a 30 grade oil. Concern is that insolubles are up. This could be from the higher detergent levels (Calcium 3193 vs 2588) in the AMSOIL cleaning out some sludge in the engine that had built up in the first 10k miles. Won't know for sure until my next sample.
Old 05-05-2008, 08:46 AM   #5 (permalink)
Thanks for making some sense out of it for me!
Old 05-05-2008, 10:11 PM   #6 (permalink)
Very nice. Thanks for the info.
Rate This Thread:
AMSOIL Signature Series Synthetic 0w30 Subdriver C66 Racing LLC - AMSOIL Direct Dealer 2 01-13-2008 08:09 PM
For the C4 Owners: AMSOIL Releases Synthetic Synchromesh Transmission Fluid (5w30) Subdriver Vendor Sales - C5 0 06-06-2005 06:45 PM
Extended Drain Interval AMSOIL Oil Analysis Results (none Corvette) Subdriver C5 Z06 - Pit Road 6 01-10-2005 11:26 AM
Mobil 1 5W30 or 10W30? DavePro C5 Z06 - Pit Road 6 02-06-2003 07:13 PM
Oil Viscosity - 0W30 vs. 5W30 z06175mph C5 Z06 - Grandstand 15 05-30-2002 02:53 AM
