Unfortunately, I have another lesson learned to share with you all that lead to the loss of my 2nd motor.
All the details are in my Runoffs race report:
http://www.z06vette.com/forums/showthread.php?t=68415
Lesson learned: The service manual does not specify putting any locktite on the harmonic balancer bolt (the main pulley on the end of the crankshaft). Apparently, when taking this bolt in and out, it doesn’t stay in as well as it does from the factory, and when it comes out the results can be catastrophic.
Recommendation: If you take this bolt out for any reason, such as putting on an underdrive pulley, putting in a cam, etc, put locktite on the new bolt.
The service manual procedure is to use the old bolt to press on the harmonic balancer (pulley) with a torque of 240 ft-lbs. Then remove the old bolt and put in a new one, torquing it to 37 ft-lbs, then rotating it another 140 degrees (which we measured to take on the order of 250 ft-lbs). New bolts do not come with locktite on them as do other new bolts like the brake caliper bracket bolts.
We took the motor apart to refresh it prior to the Runoffs. The above factory procedure was followed when the balancer was put back on. This had been the third time this motor had been apart. The first being when we inspected it from the factory. The second after a timing chain failure earlier this year.
On my 3rd lap of practice the bolt came out, allowing the balancer to warble around on the front of the crankshaft, wearing the inner edge of the balancer to a 45 degree angle and scoring the heck out of front of the crankshaft. Oil sprayed all over the front of the motor from leakage around the oil seal behind the balancer. Remarkably, the belt stayed on the balancer though it wasn’t spinning much as I lost power steering. The bolt itself did not fall off the car because it couldn’t back all the way out as it hit the power steering rack before coming completely out of the crankshaft.
It took us a day to smooth the front of the crankshaft, replace the oil seal and install a new balancer.
The car ran fine in the pits, but after two turns on the track as rpms were gradually raised, the engine lost oil pressure, with pressure dropping to 25 psi or so. After a quick check in the pits, and a return to normal 40 psi at idle, I went back out (bad idea) and the engine totally lost oil pressure and died after a half lap. While we didn’t have time to take apart the motor and see exactly what went wrong, we did see that there is a 2” diameter hole in the side of the block at piston 2, and piston 1 came up and smacked the bottom of the head.
Based on the damage at the front of the motor and loss of oil pressure suspect that we either:
- scored a bearing when metal shavings entered the motor when the balancer flopped around on the front of the crankshaft
- or slightly bent the crankshaft leading to damaged bearings when the balancer flopped around on the front of the crankshaft
After my bolt came out, I talked to at least three other T1 drivers who had this same problem and now used red locktite. I suspect that the more times the balancer comes on and off, the more likely it is for the bolt to back out. Thus, for the vast majority of you with stock motors that have never been worked, I wouldn’t lose any sleep over this. But for those of you who have made mods to your motors that are likely outside the warranty, like underdrive pulleys, I would recommend putting red locktite on the bolt when you put the new one in.
For those that have had your bolt out already, you might want to check to make sure it hasn’t backed out any.
