Need help with mystery compression readings - Z06Vette.com - Corvette Z06 Forum
post #1 of 4 (permalink) Old 05-05-2019, 02:36 PM Thread Starter
bmoss1457
I have a 2003 Z06, 140k miles with no previous issues. While moderately driving I suddenly lost significant power, feeling like I lost at least two cylinders. I limped 5 more mile to home.
No unusual noises excepts what sounded like compression bursts from passenger side somewhere. Fuel check good, spark good, plugs good. It got interesting with compression check.
#1, 2. 4 and 8 only had 25-35psi and the rest had non. on second round little to no compression on any. On third round #1,2,4 and 8 again had very low reading. Timing chain has considerable slack but no jump and marks are fairly aligned. Crank feels really hard to turn by hand at points, enough that I was forced to bump the starter to continue. Any opinions where to look next? Would excessive slack in the timing chain cause timing to be off that bad?
Can anyone tell me just how much slack or deflection in the timing chain can be tolerated before potential damage to valves or pistons?
bmoss1457 is offline
post #2 of 4 (permalink) Old 05-06-2019, 07:15 PM
jub jub
Re: Need help with mystery compression readings
Sounds like you blew both head gaskets. I have never seen both head gasket let go but I have no other ideas as to what could have happened. Were you using NOS or running boost?
jub jub is offline
post #3 of 4 (permalink) Old 05-07-2019, 06:03 AM Thread Starter
bmoss1457
Yes it does, doesn't it? That was my first thought. No water in the exhaust, oil was clean, and cooling system pressure was good. It just feels, like a timing issue. It bothers me that the crank gets into a bind about every quarter spin by hand. Its possible I guess, the chain is binding on a sprocket although they look okay, the best I can see with chain on. Going to replace them and check compression again. I just learned about interference engines, and now I'm really nervous!! lol
Thinking back, I remember some pre ignition ping during hot weather last season. At this point, pulling heads for top end service seems a good idea anyway and I'll see more of whats going on, maybe.
post #4 of 4 (permalink) Old 05-07-2019, 09:36 AM
racingvette
Z06 Tech Advisor
racingvette's Avatar
Have you checked to see if there is some bent valves or broken valve springs or lifters or push rods ?
As valve(s) stuck open would prevent the cylinder compression
Yank valve covers and check all
Did you do also do leak down tests ?
Mike M - 2001 / 2008 Z06s
racingvette is offline
  Z06Vette.com - Corvette Z06 Forum > C5 Z06 Specific Topics > C5 Z06 - Grandstand
NEED HELP...Built Mystery C6Z Frank King Car HOSTIL C6 Z06 - Grandstand 6 09-06-2013 07:04 AM
Help with AUTO TAP readings 22655TD C5 Z06 - Tuning & Electronics 9 04-28-2003 03:57 PM
What is the difference in O2 readings before/after cats. FRISKY C5 Z06 - Pit Road 15 07-06-2002 09:32 PM
autotap readings and a question or 2 SSpray C5 Z06 - Pit Road 2 07-01-2002 04:17 AM
ODO Readings?????? atuttavelocita C5 Z06 - Grandstand 19 09-01-2001 10:04 PM
