HELP, Need expert advise! - Z06Vette.com - Corvette Z06 Forum
post #1 of 4 (permalink) Old 05-09-2014, 08:15 PM Thread Starter
BRIANW401
BRIANW401's Avatar
I just performed what seemed to be the simple task of replacing the clutch master cylinder in my C5 Z06 & now the clutch pedal won't budge. The damn thing is rock solid. Everything came apart & went back on relatively smooth. The reservoir is full of fluid & there are no leaks anywhere. What could be the problem? The unit is a GM stock replacement & it came already filled with fluid which I thought was odd. Does anyone have a reason why the pedal wont budge? It moves very easy when the master cylinder rod is not connected, so the pedal itself is fine. Any input will be greatly appreciated. Thanks!
BRIANW401 is offline
post #2 of 4 (permalink) Old 05-10-2014, 07:14 AM
racingvette
Z06 Tech Advisor
racingvette's Avatar
Re: HELP, Need expert advise!
It comes with the fluid in so that the master/slave do not have to be bleed
You sure the master hose coupler is fully seated to the slave coupler ?
as if fluid cannot move then there would be no movement for rod in master
Mike M - 2001 / 2008 Z06s
racingvette is offline
post #3 of 4 (permalink) Old 05-10-2014, 07:16 AM
eagle7175
eagle7175's Avatar
just guessing but since it came with fluid their might be a "shipping plug" installed to keep fluid from leaking out???? had a twin turbo engine once that one turbo wasn't putting out boost, turned out the shipping plug was still installed and assembly technician didn't remove it. wish you luck with this.
eagle7175 is offline
post #4 of 4 (permalink) Old 05-11-2014, 07:20 PM Thread Starter
BRIANW401
BRIANW401's Avatar
Thanks for the input guys. I actually pulled it back out & went to the parts store & exchanged it out. The new one works flawlessly. I guess I just got a bad unit.
Pro Expert You Holding Out On Us? artnj04z06 The Parking Lot (non car related topics) 13 11-27-2007 05:15 AM
Need Your Expert Help: Should I get this '02 Z06 not_a_vetteran The Garage (non Vette related) 4 10-26-2007 07:43 AM
I need a KR expert....Help Please. Z06-Dave C5 Z06 - Pit Road 4 09-06-2004 04:31 PM
A Microsoft Expert diversion... sigung86 The Garage (non Vette related) 4 04-09-2002 01:01 PM
Need expert advise please TOMDEG C5 Z06 - Grandstand 9 02-20-2002 09:35 PM
