What is the difference in O2 readings before/after cats. - Z06Vette.com - Corvette Z06 Forum
post #1 of 16 (permalink) Old 05-08-2002, 07:09 PM Thread Starter
FRISKY
FRISKY's Avatar
Does the exhaust going through the cats make much of a difference on the O2 readings? Does it add or subtract from the "real" O2 numbers? Most of the dyno shops use a tailpipe sniffer. How does that compare with using the sensor in front of the cats?
"Never ever stifle someone's creativity." - Sandra Shaw
FRISKY is offline
post #2 of 16 (permalink) Old 05-08-2002, 10:17 PM
MikesZ06
MikesZ06's Avatar
MC Racing in Kansas City had me go to a nearby Muffler shop and have a 'bung' hole welded into pipe about 3 or 4 inches before the cats(didn't matter which side). They gave me a plug to take to the muff shop to put in the bung (it was threaded at muffler shop). The folks at MC don't like using the tailpipe clipon for the O2 wideband scan . They say that once the air has gone through the cats, you don't get nearly as acurate reading as you do if the sensor is inserted in the bung before the cats.
Vette Magazine article
1/4 mile pass
MikesZ06 is offline
post #3 of 16 (permalink) Old 05-09-2002, 01:35 AM
ZeeOhSix
O2 levels obviously change when going through the cats, but I don't know the exact level. That's why there is an 02 sensor before and after each cat ... so the PCM can determine how well the cats are working.
I don't need no stinkin' signature !!
ZeeOhSix is offline
post #4 of 16 (permalink) Old 05-09-2002, 02:21 AM
c4c5specialist
c4c5specialist's Avatar
HI there,
Ok, o2 sensors are use to assist in fuel metering, as they react to oxygen content of the air flowing past the sensor, once the sensor has gotten to operating temperature.
Now, the primary o2 sensors are what the computers look at for 75% of the fuel trim calculations. These are in front of the converters.
The secondary o2 sensors are behind the converters, and are described as catalyst monitoring sensors. Now, the name is not exactly correct, for the PCM still uses these sensors for about 25% of the total fuel trim calculations.
The voltages will vary, from 100 millivolts, to about 800 millivolts.
However, the primary o2 sensors will always fluctuate in this range if correctly operating. And it changes fast, as the reaction to the oxygen around it.
The secondary o2 sensors will not fluctuate that much, due to the fact of the converters, as mentioned earlier. The will show almost a steady reading, as you see a consistant voltage, due to the converting process if the exhaust gas.
If the secondary o2 sensors were to fluctuate as quickly as the primary sensors, the PCM will set a .420 or a .430 code, for Low Efficiency Catalyst, meaning that the converters are not working.
This is why there are codes set when the converters are removed.
I hope this helps, and let us know what else you need.
Besttoyou, c4c5:eek2:
GM World Class Certified Service Technician. Chevrolet Professional Service Guild. Museum member #7993.
c4c5specialist is offline
post #5 of 16 (permalink) Old 05-09-2002, 03:34 AM
VettTheRipper
VettTheRipper's Avatar
This brings up an interesting point...
Are the AFR's we seek to achieve when tuning our cars on the dyno really accurate because of the effect of the cats?
VettTheRipper is offline
post #6 of 16 (permalink) Old 05-09-2002, 05:18 AM
Roger Ramjet
I'm with you, Vette! Anybody got wide band O2 readings and stock O2 values for the same pull?
Roger Ramjet is offline
post #7 of 16 (permalink) Old 05-09-2002, 05:35 AM
BLEUBYU
BLEUBYU's Avatar
FWIW, my dynotune guy is putting the bung(s) ahead of the cats but behind the first O2 sensors - he sez this will give the most valid AFR readings. We will be doing this on 5/18, followed by an "untuned" dyno session. Even though the new LS1/LS6 edit software is not yet quite ready for release, we can at least check rearwheel h/p & Torques plus get AFR reads. I guess I am expecting a "pig rich" read, like so many others - but I wonder if the newly installed headers may reduce this situation somewhat?
Ultimately, with dyno-tuning, I hope to see at least 380 or so rearwheel translated to 435 crank using the 13% drivetrain loss estimate.
BLEUBYU is offline
post #8 of 16 (permalink) Old 05-09-2002, 09:35 AM
robbys
380rwhp 371rwtq
Bleubyu, you should have no problem with getting 380rwhp. My car with just a donaldson filter,tpis headers,and maft. Timing wot @ 22 degrees total made 380rwhp and 371 rwtq.:D
robbys is offline
post #9 of 16 (permalink) Old 05-09-2002, 10:34 AM Thread Starter
FRISKY
FRISKY's Avatar
That is really what I wanted to know.
FRISKY is offline
post #10 of 16 (permalink) Old 05-09-2002, 10:55 AM
MikesZ06
MikesZ06's Avatar
Roger, I had 3 pulls with O2 readings done simultaneous on all three. I have the graphs on my computer at home. if you want me to e-mail these to you, let me know. By the way, this was untuned with rich readings (11.7 to 11.5)...369.2 rwhp..367?rwtq. Should receive my MAFT this week and will install, adjust and redyno. Hoping to be 380+..... (Also had just installed headers and X pipe and not sure if relearn had been accomplished)
1/4 mile pass
MikesZ06 is offline
post #11 of 16 (permalink) Old 05-09-2002, 11:19 AM Thread Starter
FRISKY
FRISKY's Avatar
MikesZ06, Yes, please e-mail me the graphs.
Thanks, Carl ([email protected])
FRISKY is offline
post #12 of 16 (permalink) Old 05-09-2002, 12:03 PM
Roger Ramjet
Mike -
Sent you a PM for the O2 data.
post #13 of 16 (permalink) Old 07-06-2002, 06:49 PM
tdzee
O2 Sensor Bung
Greetings
Does anyone know where to get a titanium bung and plug to add port for dyno O2 sensor? I would not let shop add the SS one they had.
I just had my 02 dynoed (5500 mi, 357 RWHP and 344 RWTQ) with volant dual intake but no MAFT. (It is in the mail and I hope to install it soon.) Ran very rich (around 11) with tail pipe sniffer. Dyno shop said they have seen about 1/2 point of AFR change due to cats. I assume that the cats will remove some of the unburned fuel (therefore a reading of 11 was actually about 10.5).
Thanks to all for such a great forum!
tdzee is offline
post #14 of 16 (permalink) Old 07-06-2002, 09:10 PM
TAMUz06
I resolved the need for a welded in wideband O2 bung by removing my cats all together.
TAMUz06 is offline
post #15 of 16 (permalink) Old 07-06-2002, 09:31 PM
MikesZ06
MikesZ06's Avatar
That's a good idea, Tamu, except in a state that requires annual inspections (like mine) :(
1/4 mile pass
MikesZ06 is offline
how much a/f mixture difference from taking the cats off NC_EB_Z06 C5 Z06 - Pit Road 3 08-30-2004 09:38 PM
Wideband tuning with cats? How much of a difference does it make? vortech C5 Z06 - Tuning & Electronics 12 07-22-2003 10:24 AM
What's the difference between these Random Tech cats? rpallas C5 Z06 - Pit Road 7 07-15-2003 08:57 PM
FLPs: How much horsepower/torque difference between WITH vs. WITHOUT cats? SilverStateZ06 C5 Z06 - Pit Road 0 06-27-2003 03:46 PM
ODO Readings?????? atuttavelocita C5 Z06 - Grandstand 19 09-01-2001 10:04 PM
