C6 zo6 common issues for the Engine failure - Z06Vette.com - Corvette Z06 Forum
post #1 of 4 (permalink) Old 09-08-2019, 02:05 AM Thread Starter
Ahmedi1
HI,
I am planning to buy C6 Zo6 and i need to know the common issues for the Engine failure and how it can be avoided
waiting your assisting guys
Ahmedi1 is offline
post #2 of 4 (permalink) Old 09-12-2019, 05:11 PM
PeteZ06
PeteZ06's Avatar
Re: C6 zo6 common issues for the Engine failure
I sold my 07 ZO6 last year, so Iím not completely current. The only problem I had was the valve guide wear. The heads were replaced under my extended warranty. You can check valve guide wear w/o removing the heads. Loose valve guides can result in swallowing a valve, which pretty much trashes the very expensive motor. Lots of after-market fixes.
The stock intakes are titanium, expensive but light weight. Stock exhaust are two piece sodium cooled, can break instead of bend.
Good luck!
PeteZ06 is offline
post #3 of 4 (permalink) Old 09-14-2019, 12:38 PM
jub jub
What Pete said.
jub jub is offline
post #4 of 4 (permalink) Old 09-14-2019, 02:59 PM
racingvette
Z06 Tech Advisor
racingvette's Avatar
Originally Posted by Ahmedi1 View Post
HI,
Biggest problem can be is past owners installed crappy mods and a bad PCM tune
Being the LS7 is a punched out small block there is no real cylinder walls and if those changes
are not very good can cause rods going through the block.
I would get the car connected to a full OBD-II scanner and assure the fuel trims (AFR) is correct for all engine conditions,
check to see if engine is passing the on-board OBD-II smog tests as that would give a clue how good or bad engine is running.
Mike M - 2001 / 2008 Z06s
racingvette is offline
  Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 Z06 - Grandstand
