Steering Rack Boot/pipes routing? - Z06Vette.com - Corvette Z06 Forum
post #1 of 4 (permalink) Old 01-24-2018, 06:44 AM Thread Starter
GS1000FF
Hi,
my driver side steering rack boot is ruptured, by the high pressure pipe. (See picture)
It looks like it's wrongly routed, insted of in front of it should go behind (towards the back of the car) in order to clear the dust boot!?
It's one of thos PITA locations to access so any ideas before attempting to replace the boot itself?
If I disconnet tyhe pipe and move it back ... the challenge will be to reconnect it to the rack head again
All the best
Sorry for the picture orientation but you'll get what I mean.
ID:	12321   Click image for larger version
C6 07 Z06 (12-
C5 01 Z06 (owned 06-12)
C3 72 383" Pro Street, (owned 99-06)
GS1000FF is offline
post #2 of 4 (permalink) Old 01-24-2018, 11:35 AM
racingvette
Z06 Tech Advisor
racingvette's Avatar
Re: Steering Rack Boot/pipes routing?
Cannot tell with those small pictures, your eyesight is best to decide when looking at this which is best
You may find it easier to loosed the steering rack mounting bolts ( or lower the left side) so it drops down and makes more space to get the lines on or off
as you do not want to cross thread or have loose brake line fittings not tight enough
When done you might want to consider to do a wheel alignment.
Mike M - 2001 / 2008 Z06s
racingvette is offline
post #3 of 4 (permalink) Old 01-25-2018, 08:17 AM Thread Starter
GS1000FF
Thanks for quick response!
I went back to the Service manual again and !! looking at page ”15-115” it looks like the routing is different from what I see in my car.
The pipe going into the top of the ”Variable Effort Steering Actuator” actually goes outside of the two other pipes?
Probably done on the assembly line during the last ours before the weekend
I’ll follow your advice and take a closer look today.
All the best
C6 07 Z06 (12-
GS1000FF is offline
post #4 of 4 (permalink) Old 01-25-2018, 09:05 AM
racingvette
Z06 Tech Advisor
Or was the CAM changed ?
If so the rack would have to been dropped to get to the crank pulley bolt
In any case sounds like whoever put the rack on got the lines out of proper position as easier to do those lines with rack lowered
If you do lower rack you also have to remove mounting bolts for power steering unit to allow the left side to drop down
Steering rack unaligned NEED HELP kyle321 C5 Z06 - Pit Road 3 11-23-2011 05:52 AM
08 Steering Rack? ajf C5 Z06 - Grandstand 0 12-27-2007 11:14 PM
How much steering wheel play is normal? Anyone wear their steering rack? Cobra4B Racing 18 03-06-2006 02:24 PM
Steering rack removal......UD pulleys going in. DavidGP C5 Z06 - Pit Road 16 10-03-2004 03:21 PM
Steering rack blew up ls1jp C5 Z06 - Pit Road 14 09-01-2004 05:03 PM
