1 - 8 of 8 Posts
Does anyone out there know who makes the OEM
injectors for the Z06(s)??
If so, let me know.. if it's BOSCH, a part # would be
completely grand :D
I want to start looking at injector alternatives, and I have all
the internal injector size listings from Bosch and Lucas, but
they don't list applications, only Part #, Size, Pressure, Flow,etc.
Jim C.
PS: Yes, I'm already at it.. don't even have the car yet :lol:
01/02 injector
They made by Delphi and not Bosch or Lucus.
02 Z06 injectors
Sorry I made a mistake they are bosch injectors.
part number.12561462 and 0280155931
I'd double check that first number..
Hell, DC both of them.
If the 2nd # really is 0 280 155... then I need
to make a call to someone in Germany.
(My book ends in the 153's)
Jim
re part numbers for 02 Z06
I took these numbers right off the injector. Thanks for the quick reply.:-? :-?
02/01 injectors
I will be going to Agostino racing who a case of injectors taken off of new/used C5 vehicles.He uses larger injectors on his stroker displacement motors.If anyone needs 28.4 lb/hr injectors. call Agostino @ 905 420-9195. or look in GM Hi-Tech magazine.If Jim @ Halltech is correct that GM went to 24.4 lb/hr injectors on 02 Z06 then using 97-98 LS1 injector which are 28.4 lb/hr should bring my car out of it's lean condition.I think the SVO 30 lb/hr would be to large for my application @ this time.:cheers:
Re injector change 02 Z06
Just changed injectors to 28 Lb/hr. rwhp now @ 369 TQ @ 363.5 gain through out the power band in some cases more than peak. A/F ratio rich 10.8 to 1 @ wot. Now I have to figure away to lean to ideal 13 to 1 ratio.:) :)
1 - 8 of 8 Posts
