No brake in period for the shocks. I take it you got your starting problem fixed? :cheers:RC45 said:today - and first impressions are it's a little stiffer and "bouncier" than the '01 shocks were.
Am I getting the correct SOTP feel out of this? Is there a settling in/bedding in period for new shocks?
-Paul
Yes, thanks - the folks at Lone Star Chevy in Houston say it was an "internal starter" issue.IT L GO said:No brake in period for the shocks. I take it you got you starting problem fixed? :cheers:
It will be the way I drive...Resist said:I was going to put 04 shocks in my 03 until I read that the difference isn't much for street use.
I felt difference between the 03-04 shocks was very subtle as well. However, the difference between 01-04 shocks is major.Resist said:I was going to put 04 shocks in my 03 until I read that the difference isn't much for street use.
http://GMPartsdirect.comSRV said:Anyone here have 04 shocks for sale?
Thanks for responding and posting the link. :cheers:RC45 said:
Aren't used shocks like used condoms... not knowing where they've been they not wise to use..?SRV said:Thanks for responding and posting the link. :cheers:
However, I was already aware of the page. Before I order from them, I was hoping someone had a set they didn't want. I've seen used ones go for $150-200 which is a nice price-break if one can score a set.
I replaced my starter a couple of months ago with a new one from GMPARTSDIRECT and mine also stays engaged a little longer than I am used to. When I did it in order to avoid future problems I also put a Thermo Tec heat blanket wrap around the starter for protection since I installed the LG Long tub headers and it ia hot down there. In addition I put in a remote starter solenoid to move that function out of the high heat area. Better safe than sorry since any repairs to items down there require the removal of the headers starting at the catback exhaust and forward.RC45 said:Yes, thanks - the folks at Lone Star Chevy in Houston say it was an "internal starter" issue.
Extended warranty covered the $540.00 repair bill.
The new starter really whines a lot... may need to have them take a look at it.
BTW, they turned the labour on fitting the shocks and brakes because "they couldn't get to it for a couple weeks".
Go figure.
The '04 also has a diff. rate leaf spring (rear I think) and metal sway bar endlinks (instead of plastic) - so I would not expect the '01 to be 100% on par with the '04 yet.algarcia1 said:I had an 01 and traded it in for an 04. The biggest difference I felt with the shocks are on a fast curve with a bump. The 01 felt like the rear end would come out. The 04 is very stable and gives you more confidence in the same situation. Other than that, the ride itself feels the same.
You know, you're right!RC45 said:Aren't used shocks like used condoms... not knowing where they've been they not wise to use..?![]()
