You need to understand how GM commands the coolant fans, which is within the PM calibration
PCM commands what the percentage of the fan's rotation is
Looking within your Z06, the fans are only commanded to rotate 14.9% and that does not begin until 219 F deg
And does not go even then 89.9% speed of rotation until 233 Deg
PCM will also command the fans higher rotation when the A/C is on, so you may see cooler temps then and now with it off the temps can be higher
If wanting the temps to be lower than have someone tune the PCM calibration and change the values shown below
Stock Tstat is like 192 deg so as you see the coolest temp PCM can command is 89 C so with tune start commands fans on then and up the rotation throughout this table
Also swap Tstat with like a 175 % and with setting higher fans rotation will help bring down the engine bay temps
which also means the air in intake and gas in fuel rails be cooler and better charge to the cylinders
Only reason GM forces the higher temps is for smog reason but learned their lessons as look at the design of C8 which has more and larger coolers and engine temps run cooler
