what do you guys think it is?? I hear the Vararam is supposedly the sh*t. Is there any intake system out there that boasts more hp & tq than the vararam (halltec, vortex, volant, K & N, Granatelli, etc.)? PLEASE let me know!
IT L GO said:The quality could be better, the install is harder than most. The results are the best of all the intakes. :cheers:
Yes,sorryCOUTO1981 said:Are you referring to the Vararam?
I have an '03 and have not had any codes. I bought mine from LGM and they said it is very few that actually throw codes. The ones that do seem to be the ones that come from the factory on the lean side. The trap makes the car breathe better leaning it out even further out of the proper range bam codes.Bandz7 said:Droid,
I've been looking at the Halltech Trap and the Halltech Stinger for some time now, I also like how it matches the fuel rail covers. What has stopped me from buying that product to this date is the fact that I've heard that it throws codes. What happened when you installed it? Thanks
will82 said:Vortex Rammer!!!
Less expensive than Vararam
Better build quality than vararam
Easier installation than vararam
Better filter than Vararam
Less likely to ingest water than vararam
Looks cooler under the hood than vararam. (especially the clear box)
This system :jammin: on the highway, especially at speeds over 100mph.
Bandz7 said:Droid,
Z06Machine said:Don't know why, but no codes with Vram or LG's on my 04. Did the Vram first and then the LGs. Really wakes up the car.
Did the idle relearn after each install.
I have seen a few more complex variations on this but basically:FlosyZ06 said:i would also like to know what an idle relearn is.
thanks.
