I will be trying for the 10 second marker in two weeks, I need to know if anyone has run slicks on there Z06, I need to know a rim size and tire to run on the car. Any info would be great.
Optic
:cheers: :cheers:
SLP sells 16-8 1/2 take off firebird rim @ $50. You can fit the M/T 16-10 1/2 there will be some grinding necessary at the nuckle on top of the A arm. Or you can get some custom wheels but grinding will still be required. I haven't heard of anyone that has figured out how to put a 15" wheel on with stock brakes and A arm. The Aluminum is holow so only grind what you have to. Ric
I just got a set of M/T ET streets on a 16x8.5 C4 rim. It looks as if you have to do just a minor bit of grinding. I plan on running them Sunday so I will post pics of what the mod look like. It looks like you could put the 16x9.5 or 16x11 c4 rims, but it may require more grinding. I have a set of 9.5s and I am going to check how they fit also.
A friend of mine has the same size ET Streets on his Camaro. It is an MTI 422 that makes 500+HP. He cut a 1.56 60' on them Friday night. And trust me it is in the 10s.
Hello!
Ok the 16's will require you to grind, and I know that sounds bad, but it's not all that much you have to do.. Some people say the A arm, it's the cap of the upper ball joint that needs the work.
I put a set of 16's on mine, what I did was cut (I used a body grinder) to cut the top of the cap. If you look close you will see a nipple sticking up, thats all you need to take off maybe a little extra but it's not all that bad. Then take a little black paint and touch it up.
Your ready to go...
Ernie
On my car, the wheel actually hits the knuckle. The highest point of the knuckle is towards the rear of the car. When I went to mount the wheels on the car, you can see where they hit. As soon as I "clearance" this just slightly the wheel should clear just fine. As for the "cap" , this appears to be a dust cap which is about 1.5 inches in diameter. It has an inner portion which is probably about 1 inch in diameter which rises up probably and 1/8" higher than the rest of the cap. This look to be hitting on my car. I am going to do the clearnce work in the next day or so, and I will post pics of what I run into. But it looks as if it will work.
Re: Re: 10 second marker need tire options?
Roger Ramjet said:
If you are trying for a 10 sec run, what has the car got on it to get you there?
Roger I have 11.410 at 126 on street tires to get me there all I am missing is a 4,500 launch.:cheers:
