I'm looking at a 100 dry or maybe wet shot.
What is the limit of the stock z06 injector, with use with this dry shot. As you can see i have most bolt-on already and i would rather not have to upgrade injectors also. I assume if the stock injector would be over worked, then the wet shot would be the way to go??
What is a ball park costs of upgrading injector if need be- would the fuel pump need upgrading also?
