Hello:
Can anyone provide me with sound clips of the GX-2 112 LSA LG Cam, GX-3 112 LSA Cam, or T-Rex Cam?
Also, if you have a sound clip of a GX-3 114 LSA Cam (Or any 114 LSA Cam), that would be greatly appreciated.
I just want to hear the sound at idle and revving differences.
Regards,
JG853
2002 Z06
1996 GS Convertible with Black Guts
Thunder Racing's site has a clip of a white T/A at the track. You can hear it but I don't know how much idling it is doing. Click on the T-REX cam info under valve train.
D.J.
Go with the X3-112 and be done with it. If you get the X2 you'll wish you had gotten the X3. I make 350 ft-lbs at only 2500rpms with the X3-112 (stock heads). I'd go with the same cam all over again.
The T-Rex doesn't have near the low end grunt that the X3-112 does...It makes all it's power up top, which is fine if you race all the time. Did you see pictures of what the T-Rex did to a members pistons? That valve clearance is WAY too close.
