1 - 13 of 13 Posts
· Registered
· Registered
Have anybody noticed the time stamped on Scott's slips at his website? it said 9/Jun/2001 7:23 PM. OK, I live in TX and it is now 9/Jun/2001 3:15 PM. Do you live in Asia or Europe somewhere Scott? Or the date must be wrong on the computer... Other than that, very impressive numbers for first time at the track......
· Registered
Hi all,
Yes, ddle, they must have had their clock set wrong, it was Friday 6/8.
I ran with about a half a tank of gas, that doesn't explain the reaction time, must have been napping waiting for the lights. Really, I wasn't taking any lead-off, I was waiting till I saw the green light before I took off. A little practice, which I plan later to do in the next month or so (still cleaning the rubber and tar from this run), I should get into the low 12s.
G
Cool - my 5th run ever, aside from the 4 I did at the cruie-in last month, I did my 13.10 yesterday ... not bad for a completely lost driver like myself /phpBB/images/smiles/icon_wink.gif LOL
_________________
*** '2001 Triple Black Z06 Race #4851 Sequence/PVI # 008616 Born 9/20/00 ***
Halltech TRIC, CAGS, Ripper, Lots of titanium, Baer & more. C5R #Y4835
aka robnynj at one time /phpBB/images/smiles/icon_smile.gif
· Registered
Discussion Starter · #9 ·
Torchred,
I'm pretty sure all the reported times begin at the green light, including R/T. So any improvement in R/T comes right off the bottom line.
Scott
Frank, I may be hooked! Am planning next trip back to track for first Monday next month. /phpBB/images/smiles/icon_biggrin.gif
· Registered
Actually your reaction time has nothing to do with your et.
Your et droesn't start till you break the beam so you could cut a 3 second light it doesn't matter in your et.
Remeber if your just going for good et's shallow stage and forget about reaction time just concentrate on a good launch.
· Registered
If you think of it as a number of beams of light (across from each other)that when you break them certain events happen.
That is why a perfect reaction time is .500
That is because if you react perfectly you will break the start beam .500 seconds later after you reacted.
Now to really through you for a loop your mph read out in the qtr. is actually not what you cross the line at because it is the avg. of two broken beam lines. Near the finish.
· Registered
Discussion Starter · #13 ·
Thanks Silver Bullet for peaking my curiosity to look it up! I found a web site that explains the Christmas tree and the starting process, it wasn't what I expected.
Indeed you are correct R/T has nothing to do with the times. Looks like I'll have to concentrate on tire hook-up a lot more.
Thanks for your comments.
1 - 13 of 13 Posts
