Good morning!
New to the forum and having a C6. Bought the car a couple months back and went ahead and threw the TSP Stage 2.2 cam in there as well as having the stock heads gone through as far as valves, seals and upgraded springs. Took it to the dyno this week to have it tuned. The numbers seems a little low, but I could be mistaken. The tune was done in Denver with an air temp of about 50 degrees. I'm happy with the numbers, just wanting to see if this lines up with others out there. It was a Dynojet and the final pass was 496hp and 452tq. Baseline was 471hp and 432tq. Appreciate any input on this. No other mods on the car.
Z06 Tech Advisor
Good morning!
My answers would change knowing more of the facts, your image is so bad really cannot but used to analyze results
1. IF the dyno used with nothing but a "static drum, forget the numbers other then a compare if the runs were done on same day and weather.
Static is useless as the drum could weight 2,700 lbs and say car driver 3,500 lbs as that skews the true results.
Also they cannot really adjust for weather, elevation and D/A
Most cases results on a static drum produce higher results then the real numbers but those shops and car owners love it as showing high values, like saying they have a bigger dick.
2. Load bearing dyno is just that the drum weighs the car, and sets the drum through motors to add load that equals car/driver and has instruments to measure for weather and D/A thus the run is far more accurate
Car owners and shops hate these type dynos because the results will be much closer to the truth
Elevation a killer and why most in your state add boost, you maybe live at 6,000 feet.
Compare at 4,000 feet HP/Tq loses about 50 and in hot weather D/A comes up even higher
In your 50 deg weather the numbers would produce higher numbers where in summer heat the numbers drop like a log
Yes I know the ones who like phony jacked up numbers will say load bearing type sucks is only because the numbers better to real world report lower.
Image needs to be better to see, If what I think the AFR reports is, the engine will knock, pull timing and performance drops like a log
Finally the LS7 sucks as to heat, not much cylinder walls etc so and that kills the HP/Tq
cool engine and bay down the best you can to limit that loss, higher flowing radiator, tranny fluid cooler and long tube headers will increase heat in engine bay
Now let the dyno lovers start crying :smile2:
