1 - 2 of 2 Posts
Good morning,
I will start with the fact that I know which fuse the NPP is. I also know that my 2006 ZO6 is equipped and currently not functioning.
Now that that is out of the way, I replaced the 10 amp fuse as previous owner had removed and the NPP is still not functioning. No big deal, I will start with the vacuum lines near the firewall and rear of the intake and then jump down to the solenoid behind the tail lights.
My question is, the fuse label underneath the passenger footboard shows the exhaust fuse labeled as "spare" and I do not show a "EXH MDL" fuse spot as I have seen in other Z06's. Any ideas on this? Pic of label attached
That's right some Zo6 have the NPP fuse and some don't. Some cars have # system exhaust.
Leave it alone. Where is the problem?
Why you need the NPP fuse? Is it because the sound is poor and you want it more loud or there is a problem in your exhaust, let's say the other v4/v8 function isn't working, or double tube blades aren't opening?
1 - 2 of 2 Posts
