1 - 1 of 1 Posts
My 2009 HCI, long tubes, ID1000!injectors, flex fuel conversion, dynoed 637 whp...
I have started getting a P0300 check engine code under load and the car seems to not accelerate smoothly under load....I have checked the plugs, wires, grounds, etc....but I read a post that said to check my battery! It is reading about 11.5 volts when I check it....but no problems starting or anything. Could that cause the random misfire? I read that under load the injectors pull voltage from the battery?? Just trying figure this out without a visit to a tuner In KY!
any ideas?
17233
1 - 1 of 1 Posts
