1 - 13 of 13 Posts
and what needs to be replaced? Suspension-wise, are the shocks worn out? bushings wasted?
I'm still on my original brake pads, wonder what percentage I have left?
Any suggestions to make the car feel new again?
wow I didn't change out shocks until 50K miles
pads? for sure! even the stock ones will let you feel a fresh BITE.
I checked plugs/wires too at 30K, tires, battery (I changed mine out to an optima), and fluids (tranny to synth, oil to Dot 3 for the street, diff fluid)
I changed out my shocks at 58,000 miles for the 04 shocks. When I did there still was no leakage on the original shocks. So you should be good at 30,000.
I just hit the 30,000 mark as well. The car is still the best ride I have ever had. I love this car. The looks alone are worth themoney. Dr.Bigg
yeh I have the '04's too, same with my shocks at 50K, they still looked fine
Thanks for the input, maybe I should stop worrying and just enjoy what is by far the finest car I've ever owned.
30,000 here also... Just replaced the shocks but only to upgrade to the 04's..... The only issue I had was the tensioner went bad....
i changed the belts and saved the old ones for spares,new delco pro battery, 04 shocks, trans to RP max atf, diff. to mobil one and gm posi.additive ,dealer did a brake flush, induction cleaning and 4 wheel alignment.
How much does it cost to change out the belts???? What preventative maintenance should be done right now. I did all the fluids, what beside the fluids???? Dr.Bigg
What does the manual say about the 30k maintenance?
My buddy hoa 46K on his 02. It rides about just as good as my 02 with 19K. He still has the same shocks.
A lot of the answers you can get to "recommended" services at mileage intervals are in your manual, or better yet online through MyGMLink.com There you can put in your VIN and it will tell you all the recommended services and those upcoming (pretty much straight from the manual) And you can update things like oil changes and such. Plus any dealer work you have had done that is in their computer system will show up on your car's page! I found it one day and have been using it and overall I feel it is pretty useful!
You want to check your tires, alignment, plugs and plug wires.
Alex
1 - 13 of 13 Posts
