Last time I was at the track last year, I thought I missed a couple of shifts into 3rd gear - always on the same corner. Just seemed like when I used normal motion/force, it just never got into gear, and I had the clutch out before I realized it. No grinding, just had to try again, and push a little harder, and in it went. It's a long, sweeping left hander (flat) and I make the 2-3 upshift at about 6k rpm. Assumed it was just my own stupidity, didn't think much more about it. Then, yesterday, back at the track, same turn, same shift, but this time it actually grinded (ground?) going into 3rd - and I KNOW I didn't muff the shifts this time - something's not right.
I don't seem to have any trouble under normal driving conditions, but shifting in high-g situations is not good. So, I'm considering taking my car to the dealer as my warranty is up in March.
Few questions:
1) should I put the stock shifter back in before I take it in
2) is this something others have experienced (I see lots of 4th gear probs, but none about 3rd)
3) how much should I tell/not tell the dealer about what I do with the car
Car is all stock except for alignment, pads, and BPP shifter. 17k miles, never drag raced (at least since I got it at 10k miles), autocrossed often, track days whenever I can.
Thanks for any help!
Don't tell the dealer anything about your hobby.
Do a search for third gear synchro problems or tranny problems.
I had my tranny rebuilt three times and replaced the last time.
The third gear shift forks and blown synchros (made out of carbon fiber I think) were always at fault.
mikahb said:
Few questions:
1. Yes, this will eliminate any possibility for giving them an excuse.:z:
Bent shift forks, particularly for 3-4, are a common problem.
I'd take your stock car in to the dealer if it is still under warranty.
I actually missed two 4-3 downshifts at TWS last weekend as well (also both on the same corner) and am really hoping that was my error instead of the first signs of this issue on my car.
Thanks for all the good input - especially the heads up about not mentioning msiska. :lol: Gonna drop my stock shifter back in tonight and take it to the dealer tomorrow AM, hoping all works out well. I think I need to go scrub my tires somewhere as I noticed last night that some of the rubber has "migrated" from where it began life to wads in the tread pattern. I'll just tell them that I'm a "spirited" driver on the backroads!
