how much am i leaving on the table without the afr 225 heads? car allready has g5x3, lgm longtubes, v-ram, and will be getting a fast setup. how much would i be looking at with and without the afr's.
You're probably going to leave 30-50 rwhp on the table with stock heads on a 402 stroker. Without good flowing heads your car will feel like a slug. A good 402 stroker should make ~500 rwhp. :cheers:
how will the drivability be with the 402/afr 225's and a g5x3 cam. its fine now but will the new setup drive a little smoother because of the extra cubes?
Yes...it should drive a little smoother with the bigger motor. I went from a cam only / bolt on car to a stroker and the stroker drives better. Getting the tune right is the biggest problem. :cheers:
