I know the clutch thing gets talked about a lot..But, When you are running 650-700 rwhp , what clutch will stand up to these numbers...I will be at the drag strip a couple times a year, most use will be on wide open highways....I have been told the Aussie clutch will be a great choice, just looking for any other suggestions :cheers:
Unless they are a matched set with a flywheel and are factory balanced
together with balance specs and rpms spec
Spin balance the assemble with a flywheel, index together before install.
Been there done that over and over. (it wasn't a spec set up)
Just passing on info I wish someone would have beat into my head a year ago.
Thank you for the very good reccomendation...I will do just that! You would think this would be a MUST!???
